racinboy30 9 Posted March 6, 2011 Restaurant I did last week. Share this post Link to post Share on other sites
RPM Graphics 6 Posted March 9, 2011 Very cool. Wish I had an opportunity to do something like that...... Share this post Link to post Share on other sites
racinboy30 9 Posted March 9, 2011 Yeah, racecars are fun. Especially if they let you have at it and do what you want to do. Here's a few from my past stuff. Share this post Link to post Share on other sites
racinboy30 9 Posted March 9, 2011 Every single thing you see was done using strictly signblazer, no other program was used. Everything was cut using a copam 2500 and using primarily FDC 4200 and Creative specialty films. Share this post Link to post Share on other sites
Superdak 2 Posted March 9, 2011 Nice work! I can only imagine the repeat business with the amount of sheet metal they replace on a weekly basis! Share this post Link to post Share on other sites
racinboy30 9 Posted March 9, 2011 Nice work! I can only imagine the repeat business with the amount of sheet metal they replace on a weekly basis! These cars are mostly local dirt racers, many just pound the dents back out and have at it till next year. Share this post Link to post Share on other sites
ratfink 0 Posted March 13, 2011 Cool! is that your rc EDM body??(95) Share this post Link to post Share on other sites
racinboy30 9 Posted March 13, 2011 Cool! is that your rc EDM body??(95) Nope, just a customer/fellow racer. He had a new one and I wanted to see what I could do. The small lettering was a extreme hassle. I had to cut the lettering three times. Some of the lettering was less than .25inch in height. It was pretty fun, just really small. Share this post Link to post Share on other sites
randalle 50 Posted March 14, 2011 Those are awesome! I like your style. Can I drop a noob question in here? I'm pretty sure I read on the 4um that on big layered jobs they get layered on the vehicle...? Is that how you typically do the cars as well? Share this post Link to post Share on other sites
racinboy30 9 Posted March 14, 2011 Those are awesome! I like your style. Can I drop a noob question in here? I'm pretty sure I read on the 4um that on big layered jobs they get layered on the vehicle...? Is that how you typically do the cars as well? I layer everything I can on the cars, If it is like a sponsor logo or something running over a hoodscoop or something like that sometimes I will do it on a table for alignment sake. Sometimes stuff will warp going through bends and folds. If it's flat, do it right on the car. 1 Share this post Link to post Share on other sites
racinboy30 9 Posted March 14, 2011 I also wrap roofs and flatter panels with calendered vinyl as well with no app tape, dry and just a Teflon squeegee. The roof on the street stock in the first picture (black and blue #66) looked horrible, it didn't match the paint at all. I just wrapped it and problem solved. Being the way I did it covered up the mess underneath and it can be removed fairly easy later. Share this post Link to post Share on other sites
randalle 50 Posted March 14, 2011 thanks! appreciate it. Share this post Link to post Share on other sites
powerian 1 Posted March 15, 2011 Very Very nice work. If you dont mind me asking how do you lay the designs out on the car? The ones with outlines and lining it up perfectly?. Share this post Link to post Share on other sites
racinboy30 9 Posted March 15, 2011 Very Very nice work. If you dont mind me asking how do you lay the designs out on the car? The ones with outlines and lining it up perfectly?. By eye and using ultra clear transferite. Once the base color is on it's fairly easy to line everything up. I usually over extend the actual design to be larger than I want it to give me some leeway. These car are not always symmetric in size. One side and differ from the other by 5 inches sometimes. I do everything in a template of sorts. That way it goes on the cars the way it was designed. Thank you everyone for your compliments. Share this post Link to post Share on other sites
randalle 50 Posted March 17, 2011 One more question... what is the biggest size vinyl you use? Your sig says a Copam 2500... so 24" is the biggest you use? I take it there is an extraordinary amount of lining up vinyl when you install? I guess what I'm saying is that if you are doing all of that with a 24" cutter... I'm even more impressed. Share this post Link to post Share on other sites
racinboy30 9 Posted March 17, 2011 One more question... what is the biggest size vinyl you use? Your sig says a Copam 2500... so 24" is the biggest you use? I take it there is an extraordinary amount of lining up vinyl when you install? I guess what I'm saying is that if you are doing all of that with a 24" cutter... I'm even more impressed. When I design something, I keep size in mind. Yes it limits what I can do with certain things. But most racecars main panels are no bigger than 24" anyways. When I use graphics larger than 24", i design it to be split up and then use the actual panels to hide the seems. 24" numbers are huge on most cars and vehicles. Most 24" numbers won't even fit on a cars doors with graphics and such. Most track rules say at least 14" to 16" numbers. Everything can be manipulated to fit 24" on a vehicle most of the time, even wraps. Though 30 or 60" is my next purchase. I would like to make enough this spring to purchase a sp300i or older 540 for both printing and cutting. I have a few coming up in the next week and I'll post them up when I finish. Share this post Link to post Share on other sites
FBRsportmod68 109 Posted March 17, 2011 what are u charging for that work??? it looks good, but most of my racer clients wont go over 100-150 for graphics. Share this post Link to post Share on other sites
racinboy30 9 Posted March 17, 2011 what are u charging for that work??? it looks good, but most of my racer clients wont go over 100-150 for graphics. The 66 is right around 400 installed. The 119 modified about 375 and most average between 300 and 600. It take two 8 hour day for a car like the 66 start to finish. The 35 took nearly 3. Most only take a day. I get just numbers, four sponsors, crew, special thanks, and single color graphics and in two standard FDC 4200 colors $225.oo installed. That was with a discount for putting my name on the cars as well. Share this post Link to post Share on other sites
randalle 50 Posted March 17, 2011 When I design something, I keep size in mind. Yes it limits what I can do with certain things. But most racecars main panels are no bigger than 24" anyways. When I use graphics larger than 24", i design it to be split up and then use the actual panels to hide the seems. 24" numbers are huge on most cars and vehicles. Most 24" numbers won't even fit on a cars doors with graphics and such. Most track rules say at least 14" to 16" numbers. Everything can be manipulated to fit 24" on a vehicle most of the time, even wraps. Though 30 or 60" is my next purchase. I would like to make enough this spring to purchase a sp300i or older 540 for both printing and cutting. I have a few coming up in the next week and I'll post them up when I finish. Thanks! I appreciate the explanation. I was having some perspective issues with it earlier... but totally get it now. Keep up the good work. Share this post Link to post Share on other sites
oscar80 0 Posted July 16, 2011 What tracks do these cars run at? Are the indoor pics from the Arnot Mall show? Dave Share this post Link to post Share on other sites
2CT Media 25 Posted July 16, 2011 Great looking work! Share this post Link to post Share on other sites
livingagain75 0 Posted August 27, 2011 Looks nice... Share this post Link to post Share on other sites
