Neuromax 97 Posted February 4, 2011 I have had this problem since the cutter was new, the ends are closed in the software but they stay open where the cut starts and finishes. For some reason on Oracal 651 it's not as bad as on 631 but it is still there. This pic is taken on 631. I have a Copam 2500 and use signblazer. I have tried many different settings of pressure, offset, speed and I can make it better but turning the offset down to zero but it is still there. In the pic shown the speed was on 20, pressure was down to 20 and the offset was .15. I would appreciate any guidance anyone can give me! Share this post Link to post Share on other sites
Jay2703 704 Posted February 4, 2011 I would check to make sure the carriage is securely on the track. Share this post Link to post Share on other sites
Neuromax 97 Posted February 5, 2011 I would check to make sure the carriage is securely on the track. Thanks for the idea, I checked and it seems to be very secure, no movement or play in it at all. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 5, 2011 I really can't remember cause it has been a while since I cut with signblazer but does the offset in the cutter setup window change this also? or is it just set on the copam? Share this post Link to post Share on other sites
Jay2703 704 Posted February 5, 2011 Does the Copam have a setting on the machine for offset? Some have it on the machine and some do it through the software. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 5, 2011 great minds think alike Share this post Link to post Share on other sites
Jay2703 704 Posted February 5, 2011 Looks like it does, check and see what it is set to. http://screencast.com/t/nGdlloKs You can download the user manual here: http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=55&nav=0 Share this post Link to post Share on other sites
Neuromax 97 Posted February 5, 2011 Thanks guys after playing with it some more I turned off the offset in SB and adjusted it to .25 on the machine itself and it seems to be cutting solid lines now! Share this post Link to post Share on other sites
Jay2703 704 Posted February 5, 2011 Great to hear you got it working. Jay Share this post Link to post Share on other sites
