Cutting directly from CorelDraw
#1
Posted 30 January 2011 - 07:55 AM
#2
Posted 02 May 2011 - 08:43 PM
This may help if you are going to use signcut to cut them out..
And watch some of the videos here I think they even tell you the only software that cuts is Signcut and SignBlazer
#3
Posted 06 May 2011 - 09:34 AM
Bob Bigart
#4
Posted 06 May 2011 - 12:52 PM
You can cut directly from "Corel" and "Illustrater".
Bob Bigart
If that's the case; why not at least provide him with direction, if not insight as to where this can be found?
#5
Posted 08 May 2011 - 02:40 PM
I would like to see how.. I called uscutter and they told me the plug in does not work yet for corel 5. Are you talking about 5 or maybe a older one?You can cut directly from "Corel" and "Illustrater".
Bob Bigart
#6
Posted 09 May 2011 - 05:57 AM
#7
Posted 09 May 2011 - 06:36 AM
Hi Guys
First of all you must get a NULL MODEM CABLE to go from computer to (plotter) cutter.
Make sure it’s a NULL MODEM CABLE and not just a PRINTER CABLE.
Null Modem serial cables allows two DTE or DCE devices to communicate with no conflict in data transmission
Then convert your line weight to the thinnest (the one with 2 ARROWS).
Set all lines at Wire frame.
Export as a .DXF file.
Send your .DXF file to your Printer.
Set your printer preference to your plotter cutter at PRINT.
REMEMBER YOU MUST CUT FROM A .DXF file.
This works for me and I hope it works for you.
Thank You,
Bob Bigart
#8
Posted 09 May 2011 - 10:12 AM
Our standard cutting page is 3200mm Wide by 340mm High. This is good for 15" rolls of material. You can change the height as needed per roll.
Try to add an extra 10mm to whatever size your roll is for the rollers (so our artwork doesn't exceed 330mm high for a standard 15" Roll).
make sure everything you want to be cut has a hairline outline on it.
You may need to make sure there are no fills in the artwork.
Line up your artwork to the left of the page.
Then just set up your printer properties to accommodate the size of your page and cut away!
#9
Posted 14 May 2011 - 02:27 PM
#10
Posted 14 May 2011 - 03:29 PM
How to cut direct from Illustrator & COREL
Hi Guys
Thank You,
Bob Bigart
Thanks Bob!
-Mike
A man without no education has just gotta use his head.
#11
Posted 31 May 2011 - 09:33 AM
#12
Posted 31 May 2011 - 09:46 AM
Take it easy. Bob was simply answering the previous post,which said you could NOT cut directly. Unlike some people. Bob has been VERY willing to share his knowledge.I feel that it is very disrespectful for individuals to make a remark as if they know something that you don't and will not explain how or why it will work. The purpose of the forum is to help individuals that are in the same or similar field that we all are connected to. If you know that you can cut out of CorelDraw X3,X4,or X5, explain to the individual how...not as if it's some top secret from the Pentagon!
Sign Maker.
Drummer
Guardian of the gate
#13
Posted 01 June 2011 - 11:52 AM
I was able to use Signcut X2 directly from application launcher in CorelDraw X3 I would just click on signcut in the application launcher and it would take me to signcut with my artwork displayed on the page. I now have signcut productivity pro. How do I get prod. pro into corel so I can do it the same way. Right now I save my corel file as an .svg, then open sign cut, then open my file. That's fine, but I really like just clicking on the application launcher.
I understand you to state since upgrading to pro you can no longer launch from Corel as you had previously? It's been a while since I made the transition; if I remember corectly in spite of uninstalling X2, there were still some lingering files remaining in it's program file folder that I had to manually remove before I could install pro so that it would launch and run without issue.
#14
Posted 06 February 2013 - 04:40 AM
How do you add my Roland Camm-1 plotter as a printer in Corel Draw x5?
#15
Posted 06 February 2013 - 05:58 AM
When I had SCP, never had a problem 'launching' in Corel. Maybe you just need to erase the X-2, and reload the pro. Maybe then the launcher will work, maybe???
#16
Posted 07 February 2013 - 07:38 AM
Hello friends, I will say you few tricks to cut directly from COREL DRAW:
- Connect the cutter to the computer with the USB cable.
- install USCutter drivers.
- Draw the design in lines in COREL DRAW..
- Before sending to cut the design. you need to select all lines of the design and apply to the value of 0.004mm to all lines of draw. using the OUTLINE PEN TOOL. (Never forget to do this).
- Send the print design and select the cutter USCutter SERIES in the printer list. NOTE: If the design is very long (over 2 meters) then select the PREFERENCES option and then the ADVANCED option in printer windows. There, you should PAPER SIZE option USER SELECT 1300 x 8000mm.
-Send to PRINT (CUT).
AND NOW ENJOY ...
#17
Posted 10 February 2013 - 12:51 PM
Yes! You can cut from draw. theres a plug in on Macromonster.com that works great and theres also cocut a more expensive but feature rich option.
#18
Posted 10 February 2013 - 02:11 PM
Sorry, but if your using a plug in, you are not cutting directly from Corel Draw. You are cutting from ecut, 5.0 , that is the bridge between the Corel Draw and your cutter.,which is the cutting software. Just like Signcut has a Corel Draw plug in. And Graphtecs Cutting master2..has an Illustrator and Corel Draw plug in. Even SCALP software has the plug ins.Those are the cutting software to make the connection/bridge to your vinyl cutter. .
Without the cutting software features, how are you able to adjust blade offset, or overcut, on a cutter, that does not have blade offset in the cutter menu? Which most value cutters do not have...
The above person, wants to cut with out any other software. Just Corel Draw. nothing else. No plug in.
#19
Posted 04 March 2013 - 06:00 PM
I must be missing something. I've just setup my MH721, added it as a printer on my PC and I drew up an image in CorelDraw, when I hit print and selected my USCutter it sent and cut. I'm using CorelDraw X4.
#20
Posted 04 March 2013 - 06:42 PM
So.. how do you set your blade offset, when the blade offset feature is in the cutting software. Or the over cut feature, which also is in some cutting software, Are your cuts lining up perfectly, start to end?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
