sidxyz1 0 Posted January 17, 2011 Speed...er, excuse me, Skeeter: I've reset my settings to factory default after re-installing the blade--so i'm running at a speed of 30. And, wow, the idea of a 120" decal make me cringe. windasm: Yeah, I've seen that happen; but no, that's not the case here. I've had less problem since the last time I re-installed the blade, but still have an issue occasionally. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 17, 2011 Are you going to a cutter race? LOL I never run over Speed 5 . possibly 6 on very large length decals. And for over 3 years. That is the highest speed I put my cutter. Slowing your cutter down would help. I run small text at 2-3 . And I mean .2" Perfect. Mr300s has a CE5000 and he said he has no problems at Speed10, His items are not as large as mine. I run large decals all the time, that is my business, piece of cake. I started with large fullside vehicle decals from the git go. Share this post Link to post Share on other sites
Clos762 0 Posted January 19, 2011 Sounds like you are cutting too fast. I usually cut around 5 or 6. Share this post Link to post Share on other sites
HazzCoDaisy 1 Posted February 16, 2011 Clean Cut blades are THE ONLY way to go. Ross is simply awesome as are his products! I am having the same issue with my Graphtec. Right now i can cut vinyl perfectly but it will not cut thermoflex all the way through. I have adjusted everything i know how and can't figure this out. I know my cutting strip is "iffy", could this be the problem? Share this post Link to post Share on other sites
NiteWalker 10 Posted February 16, 2011 Could be. Wouldn't hurt to replace it. Share this post Link to post Share on other sites
