ditch3132
mh1351 cutting speeds and force
I have a mh1351 refine cutter and i use metamark series 7 vinyl can anyone give me some useful info on cutting speeds depending on the size of the decal. When cutting larger do you cut faster or slower and also do you use 30,45 or 60 degree blade? Can anyone help.
Typically you use a 45 degree blade for most everything. Thicker material and more small detailed things may require a 60 degree blade. Speeds also go slower for smaller items.
Thanks for your helpful information!!!.  Also do you know of any cheap but fairly good quality flatbed cutters for cutting sheet material you help is very much appreciated
