Alillowr
Trouble with a vector to cut
Ive got a vector that I would like to cut but I don' know how to make the crown with the lettering merge together with the top of the figure without having a cut mark where the figure is.  Attached is the eps which was edited in illustrator, and I am using Flexi to cut.
test.eps
test.eps
It depends on what program you are using. If you are using SignBlazer, you would select both the crow and person then select Arrange + Weld + Total Weld.
Jay
I used SignBlazer and just removed un-necessary stuff then did some welding and combining.
