rickybh 0 Posted November 10, 2010 Today I received my 28" Refine EcoCut that was delivered to my house by FedEx. Everything looked good and complete when I unboxed it. I read the manual prior to operating the unit and when I did an initial test, the cutter went up in smoke! Its as if I had a smoke machine inside my room! I bought it for $22+, paid $200 for FedEx shipping and also paid $123 for custom duties and taxes. Since it is under warranty, how do I go about my problem? Will it be replaced without me spending on the freight? Any comments, suggestions recommendations will be gladly appreciated. Regards, Cristobal Ricardo M. Hojilla P.S. I live in the Philippines Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 10, 2010 probably not. US cutter warranty states they do not pay shipping to return the unit even when defective when it arrives. If you put in a support ticket they will diagnose the unit and probably send out the parts required to fix it though http://support.uscutter.com/index.php?_m=tickets&_a=submit Share this post Link to post Share on other sites
rickybh 0 Posted November 11, 2010 Thanks for the reply. I already received a message from a support specialist and I will be providing him some pictures of the damaged components inside. I just hope that my problem will be resolved soon. Share this post Link to post Share on other sites
rickybh 0 Posted November 18, 2010 Update: A replacement power supply is on its way and I would like to thank Levi Hartzog (USCutter support specialist) for accommodating me. -Ricky Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 18, 2010 Great to hear - hopefully it didn't take out the motherboard and control panel like my first p-cut did Share this post Link to post Share on other sites
rickybh 0 Posted November 18, 2010 Ouch! That looks baaad! The only damage that are obvious on mine are the 2 bloated capacitors... http://s130.photobucket.com/albums/p276/rickybh114/Refine%20EcoCut/ Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 18, 2010 when that capacitor blew at 2:00am in a quiet basement, after my heart restarted, we found it had taken out more than the power supply after installing a new power supply, then waiting for a new motherboard, we found that did not fix it and I mailed it back for replacement that worked great - thanks to Ken Share this post Link to post Share on other sites
rickybh 0 Posted November 19, 2010 That's nice to hear. You should've seen my face when the smoke coming out of the bottom of my cutter! LOL! Update: While waiting for the power supply replacement, I brought my burned power supply to an electronics store to have it checked. Aside from the 2 blown capacitors, everything else is ok. I had the 2 capacitors changed to identical ones, went back home, installed it back and TADA... my cutter WORKS!!! The CD that came along with my cutter didn't contain SignBlazer Elements USCutter Edition and SignCut Pro. I had to download them from http://support.uscutter.com/index.php?group=default I am having problems with SignCut since it doesn't cut my test designs properly (wrong length and width) but SignBlazer works like a charm! I have installed all the necessary software/drivers on both my pc (serial port) and my laptop (usb port). I'm very happy since I can start practicing and familiarizing myself with the software as well as weeding/applying. Here are samples: 1 3/8"X 2 1/2" on my cellphone's cover... and... http://i130.photobucket.com/albums/p276/rickybh114/Refine%20EcoCut/DSC01452.jpg[/img] Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 19, 2010 congrats on the repair Share this post Link to post Share on other sites
rickybh 0 Posted November 19, 2010 You're very welcome and likewise too! Share this post Link to post Share on other sites
marcuso 15 Posted November 19, 2010 The problem is likely that this is a 110V only machine and standard voltage in the Philippines is 220V. You should not be using the machine plugged into the wall! Please find a transformer that outputs 110V, otherwise, I am afraid that you risk hurting yourself! Share this post Link to post Share on other sites
rickybh 0 Posted November 19, 2010 Thanks for the heads up. I did not plug the cutter directly on a 220V outlet (this time) but on the 110V socket of my voltage regulator. I think that the default voltage of the cutter was set to 110V instead of 220V and that might be the cause as to why my power supply got burned when I plugged it on a 220V outlet. Quoting a line from the instruction manual..."Plug the power cord in power socket of the machine and a 220V/110V AC power outlet..." This is exactly what I did and then POOF! Anyway, the cutter seems to be doing fine at 110V and I wouldn't dare plug it back on a 220V socket. Share this post Link to post Share on other sites
rickybh 0 Posted December 1, 2010 Update: I just received the replacement power supply today (via USPS) and thank God that I was only charged $7 for custom duties and taxes. I hope that my future purchases from USCutter will can be sent via USPS and not FedEx which has incredible prices with a few hidden surprises. LOL! :) Share this post Link to post Share on other sites
