dawm 1 Posted October 28, 2010 Just got my cutter yesterday and everything i cut turns out like shown above. (correct image is in white & black) As you can see from the image there's a common issue besides it over cutting and making the wrong cuts, the 90 degree cuts are end/start with an angle. It doesn't matter how big or how small or how fast i have it set to. I'm using a new MH721 (grounded) w/ SignCut and my blade sticks out about half the thickness of a credit card (as recommended) any idea's? cause this is real upsetting. also the 'TEST' cut goes perfectly. Share this post Link to post Share on other sites
Conquestgraphics 4 Posted October 28, 2010 what does the graphics look like in sign blazer is this for all files or only this one how deos regular font cut Share this post Link to post Share on other sites
dawm 1 Posted October 28, 2010 what does the graphics look like in sign blazer is this for all files or only this one how deos regular font cut The graphics look as they are supposed to in SignCut, even in preview mode with the preview cut animation all looks as it should. I havent tried any other software yet. It does it on any file. Share this post Link to post Share on other sites
Conquestgraphics 4 Posted October 28, 2010 i own 2 mh721 and have never had any issues using sign blazer, i have never use sign cut you can down load sign blazer for free if you dont have it i would atleast try it Share this post Link to post Share on other sites
dawm 1 Posted October 28, 2010 i own 2 mh721 and have never had any issues using sign blazer, i have never use sign cut you can down load sign blazer for free if you dont have it i would atleast try it ugh yeah it appears to be signcut, i just installed signblazer and ran one of the same files and it cut it almost perfectly (weeding cuts were off but it was an accurate graphic) this sucks.. signblazer looks and works like poop compared to signcut, ill have to see whats wrong with signcut now. Share this post Link to post Share on other sites
Steel546 0 Posted October 29, 2010 I had the same problem, SignCut is pissing me off. Share this post Link to post Share on other sites
hockeygirl 30 Posted October 29, 2010 What driver are you using in signcut? Share this post Link to post Share on other sites
dawm 1 Posted October 29, 2010 What driver are you using in signcut? uscutter refine mh721 via serial via my prolific usb to serial adapter. Share this post Link to post Share on other sites
travmc1 0 Posted November 1, 2010 It looks like you offset is way off and check your overcut too Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 1, 2010 definite offset problem Share this post Link to post Share on other sites
sarconastic 29 Posted November 1, 2010 I got mine to do that once a long time ago. I bought some blades and had to change my offset. They were .025 offset and I put in .250 offset. Makes a Huge Difference. like 1/4" lol Kevin Share this post Link to post Share on other sites
kenimes 42 Posted November 2, 2010 Looks like an offset setting in SingCut. Uninstall it, and reinstall it to get back to default settings. Share this post Link to post Share on other sites
