Jive 0 Posted October 23, 2010 Hello all! I have a MH-721 plotter that works great so far, the only issue I am having is that when I print text, like txt around 1" tall or so, the cuts do not complete most of the time, and I end up pulling the letters up when trying to weed. It's almost like the cutter isn't coming all the way around where it started the cut. Is this something I can adjust somehow? Or just the nature of the beast? Jive Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 23, 2010 depending on which software you are using there should be an 'overcut' feature somewhere. Or something similar..it should be checked. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 24, 2010 many times a small adjustment to the offset will help this also Share this post Link to post Share on other sites
Jive 0 Posted October 24, 2010 Thanks! I am using, for now, the Signblazer Elements software that came with it. I'll see if anything is in there. Jive Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 24, 2010 if I remember correctly the offset is adjusted on the cutter itself Share this post Link to post Share on other sites
Briguy 3 Posted October 30, 2010 I`m having the same issue when cutting 1" text , even with the 60 degree blade . In the setup menu on the cutter there is no selection for offset . I finally found the right speed and force so it won`t pull up the text but some letters it does not cut all the wayand need an xacto to trim it off . Share this post Link to post Share on other sites
Conquestgraphics 4 Posted October 30, 2010 on my mh 721 i put the blade a credit card thickness exposed set pessure to 100 and cut speed 24 it works great also in sign blazer set the off set to 30 Share this post Link to post Share on other sites
Jive 0 Posted October 30, 2010 Found out the offset is set in SignBlazer, not on the plotter. I set mine to 0.30 and it seems to be much better, still catches on some things, but not like it used to. Jive Share this post Link to post Share on other sites
Briguy 3 Posted October 30, 2010 Where do you set the offset at in SB ? I been looking through and must be missing it . Thanks Share this post Link to post Share on other sites
Conquestgraphics 4 Posted October 30, 2010 go to the cut screen then click set up you will find it there Share this post Link to post Share on other sites
Jive 0 Posted November 1, 2010 go to the cut screen then click set up you will find it there Yep, what he said! Jive Share this post Link to post Share on other sites
sarconastic 29 Posted November 1, 2010 for a properly setup blade it should only be exposed 1/2 the thickness of a credit card. Kevin Share this post Link to post Share on other sites
Pakwood 0 Posted November 13, 2010 see if theres 2 times overlay the same text, which blade do you use? 45 or 60? and it also depends the thickness os the word in the text, even a brand plotter sometimes cannot do the cut if it is a small thickness. if the thickness is small then 2mm you can have that problem, if you have Corel Draw program you can enlarge the thickness with the Contour ferrament in the Effects. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 14, 2010 for a properly setup blade it should only be exposed 1/2 the thickness of a credit card. Kevin or even less - you should barely be able to see the blade! Share this post Link to post Share on other sites
