Debra Payne 0 Posted October 6, 2010 I am attempting to cut 4 copies of the same file. For some reason in both sign cut and Blazer, it cuts one copy and then the display board says it is waiting. It does not continue after waiting for a while Do I need to reset something?? Share this post Link to post Share on other sites
Jay2703 704 Posted October 6, 2010 What type of connection are you using from you computer to your cutter? Share this post Link to post Share on other sites
Debra Payne 0 Posted October 6, 2010 usb port Has been working fine until last night Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 6, 2010 have you tried just sending them one at a time instead of qty 4? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 6, 2010 depending on how large the designs are and how many nodes. Your cutter may not have the memory for doing multiple decals. It also could be dropping from the USB. Share this post Link to post Share on other sites
Debra Payne 0 Posted October 7, 2010 Thanks for the help. I have gone to cutting one at a time. Now, what do I ask for when I go to the computer store that will replace the usb port thing. I know it is a serial Port? Can somebody describe to me what it looks like or what I should ask for? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 7, 2010 The best way is to use the serial cable that came with your plotter and a computer with a serial port in the back. If you do not have a serial port on a desktop use a serial card like this one:http://www.newegg.com/Product/Product.aspx?Item=N82E16815166003&cm_re=serial_card-_-15-166-003-_-Product If you must use a laptop (cringe) then get a Keyspan serial adapter card: http://www.uscutter.com/KEYSPAN-USB-SERIAL-ADAPTER_p_212.html This unit works best of all the adapters but you are still converting to usb. Share this post Link to post Share on other sites
mopar691 281 Posted October 7, 2010 The best way is to use the serial cable that came with your plotter and a computer with a serial port in the back. If you do not have a serial port on a desktop use a serial card like this one:http://www.newegg.com/Product/Product.aspx?Item=N82E16815166003&cm_re=serial_card-_-15-166-003-_-Product If you must use a laptop (cringe) then get a Keyspan serial adapter card: http://www.uscutter.com/KEYSPAN-USB-SERIAL-ADAPTER_p_212.html This unit works best of all the adapters but you are still converting to usb. your (cringe) made me laugh. Got a helper here cutting cloroplast right now and he was like what? i dont get it. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 7, 2010 Laptops are convenient but that's it . . . repair is more costly than replacement in most cases. A desktop of the same speed processor will outperform a laptop any day. a desktop can be easily updated (except dell) - laptop only HD and Memory is really easy to upgrade. Ohhh the list goes on and on, I can't believe how many coworkers buy them and then have something break and want to complain about the repair cost or having to replace the unit. Share this post Link to post Share on other sites
CRD 9 Posted October 8, 2010 Laptop for design (can be used anywhere even at the customer side). Simple P4 2,0 Ghz 2 GB mem desktop for the cutting and printing in a wired and wireless network. Paco Share this post Link to post Share on other sites
