kpsxtyone 0 Posted September 30, 2010 Hi, I have successfully done a contour cut using the 3 registration mark way but after the final cut it will cut across back to the origin instead of the blade lifting. I have attached a picture to better explain. (I had to draw a line using a marker for better visibility) I am using an Imac with Sign Cut Pro. Cutting vinyl is fine its just when it comes to the last object of the cut. Thanks, Ryan Share this post Link to post Share on other sites
kpsxtyone 0 Posted October 1, 2010 I tried grounding the cutter and using a keyspan with same results.. Any other ideas ? thanks, Ryan Share this post Link to post Share on other sites
