vitrodesign 0 Posted September 16, 2010 Hello, My CS630 is cutting on Y axis a bit too small: I have to extand the lenght of my drawing X 1.046 to get the right final lenght on vinyl. I do not find anything in the menu to set the Y scale. Does anyone know how to do? I find nothing about it in the manual. Another thing is: It plots like in a miror and I have to flip my drawing horizontaly to get the cutting all right. It would make my life easyer if someone could anwer to that thanks in advance Philippe Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 16, 2010 what cutting software?. Share this post Link to post Share on other sites
CRD 9 Posted September 17, 2010 For Xy read the new bie manual. paco Share this post Link to post Share on other sites
vitrodesign 0 Posted September 17, 2010 what cutting software?. I use at the moment Glasseye, witch is a cad software for stained glass design, but the problem is present with any software I try.( signblaser, artcut,...) regards Philippe Share this post Link to post Share on other sites
vitrodesign 0 Posted September 17, 2010 For Xy read the new bie manual. paco [/quote Hello, I have seen your manual, very well done. But I have a CS630 and no mode button. And in the software I use ( Glasseye ) I do not have the possibiliy to make Y comp. My only solution is to do it in the plotter itself regards Philippe Share this post Link to post Share on other sites
vitrodesign 0 Posted September 18, 2010 what cutting software?. By the way speedoggy, I have noticed your avatar seems like a stained glass. Would nt you do also glass design? Philippe Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 18, 2010 sorry, but it is not a stained glass, Just an etched decorative elongated octogon window. I remodeled a few years ago. It was purchased at a building material chain here in the US, has a reflective mirror on the outside so people can't see in. I love it. Share this post Link to post Share on other sites
CRD 9 Posted September 18, 2010 make a picture of the control panel of the plotter. if it is not the mode key it must have an other name or sign. Paco Share this post Link to post Share on other sites
vitrodesign 0 Posted September 20, 2010 make a picture of the control panel of the plotter. if it is not the mode key it must have an other name or sign. Paco Hello Paco Here are the images of the control pane and one of the display where you can see, as explained in the manual also joined, that it is only the total lenght already cuted since last reset... Thank you Philippe CSmanual_en.pdf.pdf CSmanual_en.pdf.pdf Share this post Link to post Share on other sites
CRD 9 Posted September 22, 2010 OK that is clear. CS seems to have so different display settings as the CR versions. Wonder if there is a secret menu as I assume at the factory they also do test for correct Y and X cuting. What does your distibutor says about it? Sorry I could not help you in this. Paco Share this post Link to post Share on other sites
vitrodesign 0 Posted September 22, 2010 OK that is clear. CS seems to have so different display settings as the CR versions. Wonder if there is a secret menu as I assume at the factory they also do test for correct Y and X cuting. What does your distibutor says about it? Sorry I could not help you in this. Paco Thank you anyway. Me reseller is goldenplotter on ebay. He does not know much about the use of the machines he sells as I have red on different forums... I will continue to search and if I find the "secret menu" I will let you know. I am certainly not the onlyone with this problem, but the CS is quite recent. In the mean time, I will continue to to not to forget to fip and resize my drawings BEFORE each plotting. Best regards Philippe Share this post Link to post Share on other sites
CRD 9 Posted September 23, 2010 That says enough. Do not know if you contact the factory itselve if they give away the secret menu. Worth to try. Paco Share this post Link to post Share on other sites
