dfwmom 0 Posted September 11, 2010 My cutter has started doing a very strange diagonal cut across the design for no apparent reason. This diagonal is not showing up on the preview. Can some help? I have a Refine. I have to deliver these shirts in the morning and it's already 1 am! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 11, 2010 do you have the cutter grounded to the stand? You should.. http://forum.uscutter.com/index.php/topic,22467.0.html 1 Share this post Link to post Share on other sites
jimm8dmt 0 Posted March 11, 2016 Mine is doing the same thing (SC25). I dont have a stand =(. Any other ideas? That url takes me back to the main page for the forum. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2016 Mine is doing the same thing (SC25). I dont have a stand =(. Any other ideas? That url takes me back to the main page for the forum. if using scalp it will do that till it is activated - 1 Share this post Link to post Share on other sites
jimm8dmt 0 Posted March 11, 2016 Hmmm weird... no I'm using vinylmaster cut v4 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2016 well not sure on that - I registered mine straight away so not sure what it does if not registered Share this post Link to post Share on other sites
jimm8dmt 0 Posted March 11, 2016 Thanks.. I entered the serial ID once installed and it confirmed it was activated. It's so bizarre that it only happens sometimes. It's almost like it drags the blade to a certain point, then readjusts itself to cut the remaining contour cut correctly. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2016 guess then I am with skeeter and static. is the stand grounded to the cutter? Share this post Link to post Share on other sites
jimm8dmt 0 Posted March 11, 2016 No, I didn't fork over the dough for a stand. Right now it is sitting on my kitchen counter =). I tested a theory of mine (since it appears that the only time it occurs is seconds into the first cut), that maybe the pinch rollers are too far over to the right of the machine. After adjusting the rollers a bit to the left, it seemed to fix my problem for the last two cuts. The right roller was never so far over that it was off the roller grid (or whatever that thing is called), but it was far enough to being right where the blade sits when idle. Hopefully that did the trick. Share this post Link to post Share on other sites
jimm8dmt 0 Posted March 12, 2016 ...It didnt work. It is back to cutting a diagonal line through the first cut. Major sigh... Share this post Link to post Share on other sites
Command 97 Posted March 13, 2016 Make sure your file has no "duplicate" nodes that are causing it to think it needs to make the diagonal cut. I sometimes get artifacts when I import an EPS that is poorly optimized. Is it doing it in the same spot all the time? If its doing it randomly, static or an interface problem is probably your issue. Replace the USB cable and use a different port. Share this post Link to post Share on other sites
PeaceSeeker 0 Posted September 14, 2016 I recently had this same issue, I un-grouped all the objects in the file and then cut and that worked for me. Share this post Link to post Share on other sites
icmomoney 4 Posted September 28, 2016 Check that the baud rate on your machine is set the same in your computer settings... mine did this, too, a single line diagonally across a part of the design.. Baud was set different! Hope you figure it out! Share this post Link to post Share on other sites
