kpsxtyone 0 Posted August 30, 2010 Hi, I just moved to and Imac.. pc died so i got to install the sign cut pro software but it would not communicate with the cutter. sorry im not sure which section this topic should be Thanks Ryan Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 30, 2010 try a Keyspan adapter, that is the brand name, most Mac users find this works for them. Share this post Link to post Share on other sites
kpsxtyone 0 Posted August 30, 2010 does that mean that the usb connection from the cutter is no longer compatible to the usb plug of the imac? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 30, 2010 I'm just saying that if you look up Keyspan adapter, in the search, on the forum, you will find that this solved most problems with connecting to a Mac. Sorry, but I don't use either. But this has been brought up many, many times. here is the install instructions. or put in a support ticket. http://support.uscutter.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=18 http://cgi.ebay.com/NEW-Keyspan-High-Speed-USB-Serial-Adapter-USA-19HS-/120420154018?pt=LH_DefaultDomain_0&hash=item1c0999baa2 Share this post Link to post Share on other sites
kpsxtyone 0 Posted August 30, 2010 ahh gotcha! I got the mac sofware for signcut pro with the help of their tech support. They mentioned that i need to get the drivers from the manufacturer so i also opened a ticket with uscutter. Thanks ! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 30, 2010 here are all the US CUtter drivers, look thru the list for one that is for your computer http://support.uscutter.com/index.php?_m=downloads&_a=view&parentcategoryid=5&pcid=0&nav=0 Share this post Link to post Share on other sites
kpsxtyone 0 Posted August 30, 2010 tech support from USCutters sent me the drivers and it now works great! Thank you USCutter support team! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 30, 2010 great, glad you got it. Share this post Link to post Share on other sites
kpsxtyone 0 Posted September 3, 2010 After getting it to cut i now face a new problem. With the first cut it seems that the outer line is shifted. the 1/3 of the decal was close to perfect and once it goes to the remaining 1/3 the outline is shifted. I have attached a picture. First one was cut while in win 7 and next was with the mac. Anyone experienced this before? thanks ! Share this post Link to post Share on other sites
