zencut 0 Posted August 27, 2010 Recently purchased a CE5000-40 cutter to cut labels of various sizes and shapes. After trying to cut a printed image using Illustrator CS4 and Cutting Master 2 without good results. The image is centered on a 8.5 X 11 sheet with cut line (ellipse) and register marks printed from Illustrator. The sheet is loaded onto a carrier and aligned with the bottom right corner. I send the data file using Illustrator and Cutting Master 2, Cut/Plot. The cutter reads the register marks and cuts y=1.9" and X1.4" from image. I tried to offset but keeps on moving away from image on subsequent cuts on same image. Any help is appreciated. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 27, 2010 have you watched these videos yet? Alot of great info here. http://forum.uscutter.com/index.php/topic,28060.msg223443/topicseen.html#msg223443 Share this post Link to post Share on other sites
