Connor 3 Posted August 21, 2010 I cant figure out how to create an image in corel draw x5 and export it to sign cut to be cut. Everytime I export an image into sign cut it tells me it will take hours to upload my image and then half way thru stops and nothing has been done. How do i get my images into sign cut so i can create some vinyl decals? Share this post Link to post Share on other sites
knucklehead 530 Posted August 21, 2010 Should be an application launcher, on the top tool bar, some call it a rocket launcher. Click on it, and a drop down box should appear with send to sign cut listed. Unless they've changed something in X-5 Share this post Link to post Share on other sites
mailman 1 Posted September 14, 2010 I am having the same problem, there is a patch available from sign cut, it is on the web page, it has not worked for me yet. I upgraded from Corel x4 , so I am using X4 for cutting and X-5 for printing . Would like to get X5 up and going it has some nice upgrades, and I really like sign cut. If you have mcafee virus protetion, you have to disable it to install patch. Mark Share this post Link to post Share on other sites
Lancermr 1 Posted February 20, 2011 Hi, i have Corel Draw X5 and Flexy sign i just save the file in AI format an then import it on Flexy. I needs to weld items sometimes but works good. Im trying now to cut direct from CDRX5 does anyone knows how? Share this post Link to post Share on other sites
CRD 9 Posted March 6, 2011 You cant directly cut from any corel draw version or adobe illustrator. You always need a plug in like signcut or liek you do now use other cutting program to cut your files. That is life. Paco Share this post Link to post Share on other sites
jeremySI 18 Posted March 7, 2011 Hi, i have Corel Draw X5 and Flexy sign i just save the file in AI format an then import it on Flexy. I needs to weld items sometimes but works good. Im trying now to cut direct from CDRX5 does anyone knows how? If you have a graphtec you can use the cutting master plugin Share this post Link to post Share on other sites
RHConcepts 16 Posted May 3, 2011 You cant send files to Corel Draw X5 yet, the plug in does not work. You need to export the file out as a EPS or AI file. If you use AI then in the next screen you have a chose of compatibility, here you want to change it to AI 3.x. Then check Preserve curves and text by removing transparent effects and put a check in Curves. Thats what works for me but I just started.. Oh the plugin should be fixed in a mo or 2, thats what I was told. Share this post Link to post Share on other sites
