kboyte
help with welding letters--if possible
I need help or instruction on welding the letters STATE CHAMPS in the banner.  When I cut this with my cutter it is cutting out the outline in the banner.  I am wanting it to combine the outside of the letters to the banner and only cut out the inside of the letters.
Hope this is not too confusing.
Thanks
Kim
state champs.EPS
state champs.EPS
First thing u need to do is move the letters closer so they touch each other.
Then weld the letters -outline-place over banner where u want it weld the whole thing.
Should work.
mark-s
Ok, I'll try that.  Cutting software- signblazer. I also work in Corel x4 and Inkscape.
If it was me I`d start all over again.
There are alot of double lines which will hinder u in the welding.
And alot of broken lines that don`t help.
I redid the word state.This is what it should look like.
mark-s
Here is another copy that I have worked on.  I started over, outlined and welded.  When I used Corel weld it welded everything was black.  No white on the State Champs.  I got it to work correct (I think) in signblazer.  Let me know how this looks or do I still have double lines and broken lines.
thanks for any help
Kim
state champs.EPS
state champs.EPS
