jmatson 2 Posted August 10, 2010 Ok so my machine is cutting stuff way to long. I was cutting a item that was 21in long. if i cut it length of the vinyl it does fine. but when i flip it to cut across the width of the vinyl it cuts it full 24in long. i'm using SignCut as my software Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 10, 2010 possibly post some pictures of your cutting screen, maybe someone can see something, that is not right then. Share this post Link to post Share on other sites
jmatson 2 Posted August 10, 2010 here are the main screens Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 10, 2010 are you starting far enough to the right edge to get it on your vinyl, and hitting the origin button? Guess I'm not to sure of what you are saying, It is cutting the whole design from one edge to the other edge? so your design is actually 24" wide Share this post Link to post Share on other sites
MikeOswald 0 Posted August 10, 2010 I am no expert on the pcuts, but on mine pcut machine, it has a x-scale and a y-scale on the control panel. Somehow your y scale seems to be too long. Try bringing that number lower 50 or so and try it again, remeasure it and adjust as needed. Share this post Link to post Share on other sites
CRD 9 Posted August 10, 2010 Read the newbie manual first in the instructional section. Paco Share this post Link to post Share on other sites
jmatson 2 Posted August 11, 2010 Here are pics of what i cut. as you can see it made them 22.5 Share this post Link to post Share on other sites
Guest Posted August 13, 2010 Open SignBlazer, click Cutter, then click Setup. You should see the Cutting Size Correction on that screen. Click that and run the calibration. That should solve the problem. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 13, 2010 Open SignBlazer, click Cutter, then click Setup. You should see the Cutting Size Correction on that screen. Click that and run the calibration. That should solve the problem. You might want to reread the OP's post, they are using Signcut. Not Signblazer. Share this post Link to post Share on other sites
Guest Posted August 13, 2010 Oops! :X Open SignCut, click Cutter, click Calibrate Cutter Size, run the calibration. Share this post Link to post Share on other sites
jmatson 2 Posted August 14, 2010 i have tried that before. and it never cut anything. But i will try it again. Share this post Link to post Share on other sites
jmatson 2 Posted August 14, 2010 ok well it worked. i had to do it twice. it cut 11.5w x 11.25l Share this post Link to post Share on other sites
jmatson 2 Posted August 14, 2010 it's better. my 22in cut is now 23 not 23.5 Share this post Link to post Share on other sites
