nateslate 0 Posted August 5, 2010 I recently bought an EcoCut through UScutter and I'm having a hard time using it with my Mac. First let me say that I'm new to vinyl cutters, so everything is very new and scary to me. With that said I'm also a graphic designer so I have a good handle on files being used and sent to the cutter. I'm using a Dynex USB to Serial cable, and was told by their support that the cable should just be plug and play. So is there a driver I need to download specifically for my EcoCut? I've looked online and haven't seen a whole lot of info on the EcoCut. Any help you guys can give me would be greatly appreciated. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 5, 2010 alot of Mac users are having better luck using a Keyspan adapter, that is the brand name Keyspan, and can be purchased at many locations and online, You can also do a search of Keyspan in the search on this forum, and it is fixing alot of problems. Share this post Link to post Share on other sites
nateslate 0 Posted August 5, 2010 Thanks Speedoggy. I may have to buy another cable. Do I need to install a driver on my mac for my cutter like you would for a printer, or should I be able to just plug the cord in and start cutting? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 5, 2010 You will have to follow the instructions for the machine, setup, and computer. Ecocut is a Refine just like MH Series and it says Signblazer, but use Signcut for the Mac http://support.uscutter.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=16 your welcome Share this post Link to post Share on other sites
nateslate 0 Posted August 5, 2010 Once I've installed the usb driver for the cutter should there be a new option under the output device/ port option in SignCut regardless to the kind of cable I'm using? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 5, 2010 Sorry, I don't know anything about a Mac and how it shows anything. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 6, 2010 maybe this will help http://forum.uscutter.com/index.php/topic,22143.0.html Share this post Link to post Share on other sites
mzuleger 0 Posted August 27, 2010 nateslate - were you able to get your cutter to work? it sounds like I'm having the same problems you had. I can't get my ecocut to respond at all. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 27, 2010 nateslate has not been on since 8/8 so probably no answer there. just submit a ticket to USCUTTER from the support section, Share this post Link to post Share on other sites
