neeboy74 0 Posted August 3, 2010 So I've plugged in my LaserPoint 24 cutter; it says it needs to load UBS-Serial Drivers. Ok, done that, everything looks ok. I've drawn a test file in SignBlazer Elements, and I get the attached screenshot; the cutter sits there like a paperweight saying "On-Line." Nothing Else happens. I will also mention that there was no "LaserPoint" listed in the available machines when I started SignBlazer for the first time. I have donwloaded the PDF manual for the cutter and read it, set the machine up, tested it with the "Jog" function and everything. But, like I said, it won't budge when I click on "Cut Tile" in the program. When I press "Cut Tile" I get a blue rectangle around the border and a diagonal dotted line through that rectangle... Thanks in advance for any help! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 3, 2010 everything you need to know http://forum.uscutter.com/index.php/topic,17489.0.html Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 3, 2010 and a Laser Pointer is a (Creation Pcut) with a Laser. That is what you should have in your Signblazer. as the cutter. Creation Pcut Share this post Link to post Share on other sites
neeboy74 0 Posted August 3, 2010 and a Laser Pointer is a (Creation Pcut) with a Laser. That is what you should have in your Signblazer. as the cutter. Creation Pcut Thanks, that worked lickety-split right away! You RAWWWWK! Share this post Link to post Share on other sites
