key1406 0 Posted July 18, 2010 need your help have Chinese desktop cutting plotter that work well two months ago and stopped using them But now, when run with the softwear are not running and all settings are good and used with anothera computer , but also not working Share this post Link to post Share on other sites
mars 45 Posted July 18, 2010 You say all settings are good but on a new computer it no longer works? What port are you using to connect on the new computer? What were you using on the old one? Did the old one stop working? What software are you using? Give more information and someone will try and help you with your problem. Welcome to the forum - I hope you get the cutter going. -Mike Share this post Link to post Share on other sites
key1406 0 Posted July 18, 2010 Thank you Mike for your reply I use port com1 For both the old and new Computers all Settings Correct And used a new cable softwear use inkscape and signcut i tested on more than a computer, but the problem still Share this post Link to post Share on other sites
Brandon_Davis 1 Posted July 18, 2010 Without more information like, -Operating System -Cutting Software -Type of Cable used to connect cutter to computer -Type of Cutter It will be hard to point you into the right direction. Sounds like your assuming the settings should be exactly the same from computer to computer this can sometimes lead to a mistake in settings. Share this post Link to post Share on other sites
mars 45 Posted July 18, 2010 Does it still work on your old computer? Do you still have the old cable - maybe the new cable is defective? Does the machine seem to power up correctly? Will it do a test cut? I run my cutter on LPT1 (parallel cable) - if that is available get a cable and try that. -Mike Share this post Link to post Share on other sites
