tbenefi33
sign cut doing this
Signcut started doing this. This is a tree that it drew and went at  it at a angle then finished as you can see in the pic I'm stumped.
1. Check the artwork in wireframe in the design software.
2. Reset machine.
3. Check static.
I have it grounded from the base of the screw and to the stand also was thinking a crazy I just recently got a memory up grade chip and it came in one of thoses static bag I was thinking of putting the static bag around where the cutter box think thight might help with some of the static or just a crazy ideal ?
an open endpoint in the wireframe is what I meant by unclosed path.  I'm used to using illustrator terms. :thumbsup:
I'm glad you solved it. I always check my designs in wireframe before cutting as it will show any imperfrctions.
