wenico 0 Posted July 1, 2010 I have been trying to increase the pressure on my Pcut 630 I found the Pressure control and changed it from 100 to 150 Now my Pcut 630 does not receive the file for cutting. The file seems to go through but the plotter does not fire up and cut. Any suggestions. he past when this has happened I have just turned the plotter off and then back on and it has cleared it but at present it is not fixing it. I'd appreciate some advice. Regards Roy N. Share this post Link to post Share on other sites
jhelms 5 Posted July 1, 2010 check your setup and make sure that your comp. recognizes the cutter goodluck jhelms Share this post Link to post Share on other sites
wenico 0 Posted July 1, 2010 You might have a point there about the set up I can't seem to see it anywhere and yet when I disconnect ti and connect it I get the computer tone. Where should I see the Pcut and how should it appear. Regards Roy N. Share this post Link to post Share on other sites
wenico 0 Posted July 2, 2010 I'm still trying with this one. When I switch to Off Line... I can access a few things with mode. When I hit online again the Pcut goes through several lengthy test cuts that last a few minutes. Is this normal The plotter is still not receiving the file I am sending and won't cut. It does cut the test file from mode. Regards Roy N. Share this post Link to post Share on other sites
Brandon_Davis 1 Posted July 2, 2010 Stay tuned for a comprehensive post Roy... Tonight - well tonight for me - LoL Share this post Link to post Share on other sites
wenico 0 Posted July 2, 2010 Thanks Mate... I'm desperate Regards Roy N. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted July 2, 2010 first thing to check would be the baud rate. It has to be the same in your cutter settings and your software settings. I think the creation is 9600. If that doesn't solve the problem... In software settings, make sure flow control is set to hardware Make sure the USB port is correct in your settings. You should be able to tell which port it is on by going to your device manager in Windows. If you can't...once you get the first 2 things right, just keep changing ports in the software til it cuts. Share this post Link to post Share on other sites
wenico 0 Posted July 5, 2010 Thanks for that Something had changed the Baud rate on the PCut It was set to 19200 or something That was a very scary weekend... This was my final trial before I lashed oput and bought a new Pcut tonight. Thank you you've just saved me money that I can't afford and have made my day. Regards Roy N. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted July 5, 2010 I'm glad I was able to help you..I suspected the baud rate from the beginning...usually the first thing to check. Share this post Link to post Share on other sites
wenico 0 Posted July 5, 2010 Sorry John I didn't realise that the suggestion came from you I am extremely grateful and delighetd that I was only watching the unit on Ebay and hadn't placed a bid yet. Regards Roy N. Share this post Link to post Share on other sites
CyberSultan 6 Posted July 5, 2010 John's always a great help! Share this post Link to post Share on other sites
BannerJohn 1,324 Posted July 5, 2010 Stay tuned for a comprehensive post Roy... Tonight - well tonight for me - LoL Share this post Link to post Share on other sites
Dakotagrafx 7,133 Posted July 6, 2010 Stay tuned for a comprehensive post Roy... Tonight - well tonight for me - LoL I must have missed it before it was deleted Share this post Link to post Share on other sites
Brandon_Davis 1 Posted July 7, 2010 Posted it to his other string... Share this post Link to post Share on other sites
alikat1109 0 Posted November 1, 2010 Im new at this, and have the 630. I have had it cut 2 x's. I it won't cut. I have checked the baud rate. I am running windows 7, does that have anything to do with it? Please help. Thanks Share this post Link to post Share on other sites
CRD 9 Posted December 28, 2010 http://forum.uscutter.com/index.php/topic,17489.0.html Share this post Link to post Share on other sites
inksane 2 Posted January 14, 2011 i just bought a pcut ct630 off ebay and i am having the same problem as what was happening above. i checked everything you said to check and everything is fine, i also called up us cutter and one of the techs remotely logged into my computer and gave it a try with still no luck. any advice as to what i should do about getting the cutter to actually "cut" something. i am new to this stuff, so i know very little as far as operating a plotter goes. Kyle Share this post Link to post Share on other sites
inksane 2 Posted January 14, 2011 btw i am running windows 7 if that makes a difference. Kyle Share this post Link to post Share on other sites
mr300s 1,272 Posted January 14, 2011 You might be better off starting a new thread with this question as this is a old one. Will need a little more info also as to what it is or not doing and has it cut at all and what program are you using and what are you trying to cut? Share this post Link to post Share on other sites
