gogetemgraphix 1 Posted December 18, 2007 ok, i tried following the instuctions for the two color sticker.....with no success. :notsure: what i am wanting to do is cut a 92 in the Hankyshadow font in two colors. when i put the 92 in inkscape and open the trace window, i don't know which item to select and i don't have an update button...that i saw lol and i can't get it to do anything that way. in the past i have just cut it twice and reversed the weeding, which tends to waste some vinyl at times and i have found the cutter doesn't cut the same twice which leaves a hairline between the colors. i figure i need to learn to do it the right way and i have time now that things are slow. can someone help me please..... thank you lue anne Share this post Link to post Share on other sites
dgreenh 9 Posted December 18, 2007 I'm not following what you are saying. How many objects do you have on the screen and what are they? If you typed the 92 in inkscape then it is a font, not a bitmap so it doesn't need to be traced. I'm thinking that you want the number 92 in lets just say Red with a Black outline then layer the red on to the black? Share this post Link to post Share on other sites
gogetemgraphix 1 Posted December 18, 2007 ok, guess i did make it a little complicated...sorry. i want to cut the 92 in gold outline and black #'s....background gold #'s black. Share this post Link to post Share on other sites
mark-s 1,126 Posted December 18, 2007 Post your graphic....let take a look mark-s Share this post Link to post Share on other sites
dgreenh 9 Posted December 18, 2007 Something like this? Not the font but at this point it doesn't matter. Share this post Link to post Share on other sites
gogetemgraphix 1 Posted December 18, 2007 yeah except outline is much thicker lol....how do i separate the two to cut them? thanks lue anne Share this post Link to post Share on other sites
dgreenh 9 Posted December 18, 2007 When you import the eps into your cutting program there should be a place to select which color you want to cut. Pick one, cut it, Pick the other and cut it. In Signcut there will be color boxes along the upper right side of the screen. Click the color you want to cut. I uninstalled Signblazer so I can't look to see what it has. Don't forget to make yourself some kind of registration marks so you can get the colors to line up when you layer them. Share this post Link to post Share on other sites
gogetemgraphix 1 Posted December 18, 2007 registration marks is one of my many problems...lol i do not understand those at all please have some patience with me.... here is my font so you can tell me exactly what to do so i can learn this. i use signcut thanks lue anne HANKSI__.zip HANKSI__.zip Share this post Link to post Share on other sites
dgreenh 9 Posted December 18, 2007 OH, that is different. You want the shadow in gold and the inside in black. Like this? Share this post Link to post Share on other sites
gogetemgraphix 1 Posted December 18, 2007 that's it :woohoo: Share this post Link to post Share on other sites
gogetemgraphix 1 Posted December 18, 2007 if i got them separated couldn't i just set the black on top without using registration marks? but i still need to know how to do that regardless. Share this post Link to post Share on other sites
dgreenh 9 Posted December 18, 2007 Ok, not too hard to do... harder to explain. You want directions in Inkscape or Corel? Attached is an eps with registration marks (square with a circle cut in the middle). The black and gold registration marks are stacked on top of each other so you can only see one color but both will cut. Cut both colors then align the squares on top of each other to get them lined up when you layer the vinyl. You don't have to use registration marks but it sure is easier to align the layers with them. I'll type up a walk through later tonight on how I did that. Quittin' time, dinner time! 92.eps 92.eps Share this post Link to post Share on other sites
gogetemgraphix 1 Posted December 18, 2007 :thanks: i use both but for numbers i use inkscape because i can save it in eps form, so probably inkscape directions....corel tends to get a little more complicated for me....right now anyway. lol i plan on cutting the background in gold chrome and cutting the #'s in diffracto black...i think that will look pretty awesome..... :notsure: lol thanks lue anne Share this post Link to post Share on other sites
dgreenh 9 Posted December 18, 2007 Inkscape Directions: Type your number, size it and select it. Click PATH > Object to Path to convert the font to a curve With the text still selected Click PATH > Break Apart Everything turns black Click on the bottom of the 9 and change the color Click on the bottom of the 2 and change the color Now you should have your outline color done Click in the middle of the 9 where the hole is to select it, Hold down the shift key and select the black in the 9. Now click PATH >Difference That should cut out the hole in the 9 so the gold shows through. If you want, you can select the yellow in the 9 and the 2 and weld them together using PATH >Union Do the same for the Black. Thats it. Share this post Link to post Share on other sites
mark-s 1,126 Posted December 19, 2007 I cut each color seperately using regisistration marks. Sent the regisistration marks about 1 inch higher than the highest point of the graphic. Then cut seperately Use wet app to get them correctly lined up. Done. mark-s Share this post Link to post Share on other sites
dgreenh 9 Posted December 19, 2007 Yeah, you import the resulting eps into your cutting program and cut each color seperately then align them using the registration marks. Wet is really best so you have some time to do some fine tuning. The above proceedure is kind of specific for the particular type of font Lue Anne selected to use. As it was, you could only color the shadow because the inside of that font is hollow. So you have to break it apart to get all the pieces back to color them. Share this post Link to post Share on other sites
crash5050 0 Posted December 31, 2007 I have a 2 color cutting question. Let's use the afore mentioned 92 that has a gold background and a black foreground. When I try to do this, I have to cut complete graphics, ie. 2 92's one in black and one in gold, then align them and squeegie the heck out of them. My question is, is there a way to only cut the visible gold, as to not create a thick graphic. Crash Share this post Link to post Share on other sites
dgreenh 9 Posted December 31, 2007 You can trim out the black and fit the gold inside instead of on top. Problem is, #1 getting it aligned EXACTLY right and #2 when you do get it aligned exactly right, vinyl shrinks over time... rather quickly actually. Your perfect alignment will pull apart and there will end up being a gap between the gold and black. You could draw the graphic to overlap the edges but that doesn't guarantee that you still won't have too much shrinkage. At least this is my experience with it. Share this post Link to post Share on other sites
gogetemgraphix 1 Posted January 16, 2008 ok, here i go again.... when i put my gold and black 92 in signcut and i select the gold to cut at 20"tall , when i go to cut the black to put inside the gold ....what do i cut that at for inches? is it still 20 or do i need to reduce it and to what? thanks lue anne Share this post Link to post Share on other sites
mark-s 1,126 Posted January 17, 2008 It should be automatic....just the way you see it....it should cut the same.... mark-s Share this post Link to post Share on other sites
dgreenh 9 Posted January 17, 2008 You need to make the whole image 20" (probably before you import it into signcut actually) Then just cut it, should come out right without specifying a size. Signcut isn't really a great program for anything but cutting. I don't mess with my graphics in signcut, I have them sized and ready before I import. Share this post Link to post Share on other sites
gogetemgraphix 1 Posted January 17, 2008 i have never sized them before importing, i have always put the sizes in in signcut. i will try it and if i can't figure it out....i'll be back...... lue anne Share this post Link to post Share on other sites
gogetemgraphix 1 Posted January 17, 2008 got it.... :woohoo: do you need to save it or just import it? thanks a bunch guys!!! lue anne Share this post Link to post Share on other sites
dgreenh 9 Posted January 17, 2008 If you are going to use it again, I would save it. Share this post Link to post Share on other sites
gogetemgraphix 1 Posted January 17, 2008 ok, imported it to signcut and nothing comes up... :why: lue anne Share this post Link to post Share on other sites
