Has anyone had to replaced a Z-Chip in a MH-721 Cutter and if you have cane you walk me through it I know where it goes I just dont want to put it in upside down and melt my Mother Board. I cant get anyone to answer at Tech and need my machine really bad. It takes me 5 to 7 days to get my stuff when I order it , I am in Ky. Need help bad have a big job to do and really cant wait until Monday.
Not sure what the z chip is... but most changeable chips have a notch cut out of one end if you put the new one in with the notch in the same way you should be good to go...
MM64  ;)
Guest manwayvan
Some will also have a dot indicating the number 1 pin.
Guest HowardI
The "Z Chip" is the chip that regulates carriage vertical motion.  It controls the up signal, and the down signal.
If the knife goes up upon power up but will not go down, this is likely the culprit.
It can be the culprit even if there is no movement vertically but in this case its not the only possibility.
It's easer and faster and to ship this chip than to have someone replace their entire motherboard.
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
Just replaced the ZChip on the MH-721. Now, the head doesn't move at all. Before, it was springy - you could push it up or down with your finger. Now, it's very stiff - it will move up or down, but there's resistance when you press on it and it doesn't move at all when cutting.
Could it have been installed wrong? Could something else have happened when it was installed to be causing this?
Thanks.
