runjohnray 0 Posted June 11, 2010 i have a creative 24in plotter i am trying to plot out of AutoCad 2010. What do I need? Share this post Link to post Share on other sites
Mr Peabody 0 Posted June 11, 2010 I don't know about the Creative plotter, but you can set the plotter(cutter) up as a printer and just use the plot command. It should work just like any other plotter. One setting you might want to check in your setup is making sure your set to HGPL. I have cut vinyl using Autocad on my Graphtec. No problems. Share this post Link to post Share on other sites
Guest crshirts Posted June 12, 2010 The refines will not sure if pcut will. If you can set it as a windows printer it will work. Make sure you set it up and calibrate in autocad Carl Share this post Link to post Share on other sites
