Spike
810, 811, 810S, 813 or 651
Ok, been using the 813 for a while now and need something thicker and less tack.
Spraying lacquer through airbrush
Cutter = Craft Robo
Thoughts and ideas?
Thanks
Spike
I don't have a clue as the ones you use are all listed as low tack
We need advice from one of our painting gurus
Why do you need more tack?
The 651 will be really hard to get off.
he needs less tack
What are you applying the paint mask to? I've used both 810 and 813 for years and never had a problem with it being too tacky... The only problem I have with them is when I used the wrong roll of app tape, I have a hard time getting the app tape off without tearing the paint mask.
MACTAC- Transparent Gray Paint Mask and Clear Choice AT60(app.tape).The paint mask has water based adhesive ,so spraying lacquer is OK. I use this paint mask almost every day and love it.Cheers
