jrandl 0 Posted May 19, 2010 SUNIE arrived yesterday, calibrated perfectly right out of the box. It is working perfectly. Question for other SUNIE owners. Did your 15x15 come with any sort of base or rubber feet. Mine just has a very rough metal bottom, not even level. It also does not have any way of anchoring it for stability. Thanks for your replies Jason Share this post Link to post Share on other sites
Guest sciondrgn Posted May 19, 2010 I have an older sunie but it is just metal on the bottom.. I put one of the large over sized mouse pads underneath mine and that fixed it up. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 19, 2010 I have an older model Hix that is the same way. It is mounted with bolts to a plywood base,which I think is how it was meant to be. Share this post Link to post Share on other sites
CyberSultan 6 Posted May 19, 2010 My Sunie is the same way, just a metal base. It is working ok for me as is, but I'm sure you could put some rubber feet on it if you need some stability or leveling. Share this post Link to post Share on other sites
hockeygirl 30 Posted May 19, 2010 I put rubber feet on mine. Just a simple $1 pack from Walmart did the trick. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 20, 2010 Mines on a bench and I never looked at the base! Share this post Link to post Share on other sites
