jrandl
SUNIE Press Base Question
SUNIE arrived yesterday, calibrated perfectly right out of the box. It is working perfectly.
Question for other SUNIE owners. Did your 15x15 come with any sort of base or rubber feet. Mine just has a very rough metal bottom, not even level.
It also does not have any way of anchoring it for stability.
Thanks for your replies
Jason
Guest sciondrgn
I have an older sunie but it is just metal on the bottom.. I put one of the large over sized mouse pads underneath mine and that fixed it up.
I have an older model Hix that is the same way. It is mounted with bolts to a plywood base,which I think is how it was meant to be.
My Sunie is the same way, just a metal base.  It is working ok for me as is, but I'm sure you could put some rubber feet on it if you need some stability or leveling.
