ddm00767 0 Posted May 16, 2010 OK, finally had the MH871 up and running, cutting the banners. 2nd on, had test fed twice, did ok, Started cutting, almost at end the head got under the vinyl and got stuck. hit the reset button, stopped but was at kill button. Pulled out vinyl, cut it off, turned off machine, pulled head to middle, turned on, hit reset. head keeps running straight to red kill button. Now what??? Share this post Link to post Share on other sites
boosted 2 Posted May 17, 2010 dont forget to reset your origin. Share this post Link to post Share on other sites
deth502 39 Posted May 17, 2010 if im following what your saying correctly, yes, the head will bump up against the red button whenever you initialize the cutter. Share this post Link to post Share on other sites
