mabco12 0 Posted May 5, 2010 Does anyone have the proper pressure settings for the pinch rollers or a surefire techiques for adjusting the pinch rollers? Share this post Link to post Share on other sites
MrMopar64 47 Posted May 17, 2010 Well I don't know if this will help but on mine I run the brass knobs so they were all even with the top of the screws.... thinking that would make them all about the same. It's worked fine for me MM64 Share this post Link to post Share on other sites
mabco12 0 Posted May 17, 2010 I will give it a shot!! Thanks MM64 Share this post Link to post Share on other sites
Outdoors4life 0 Posted June 23, 2010 Did this work for you? Mine were like that and they seemed too tight and left marks on my vinyl. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 23, 2010 marks are normal on the lower end machines but will go away when installed Share this post Link to post Share on other sites
Outdoors4life 0 Posted June 23, 2010 Thank you very much! I was a little worried. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 23, 2010 nothing to worry about Share this post Link to post Share on other sites
Guest HowardI Posted June 25, 2010 Thanks Dakota. That's how we always reset them. Screws flush with the brass knobs. The marks do go away, they are really in the backing not the vinyl but the vinyl is stuck to the backing so . . . The factory also sets them flush. Howard Irwin Support Specialist US Cutter 425-481-3555 888-298-8143 - Option 2 Share this post Link to post Share on other sites
