Been cutting some longer vector images lately (48" +) and noticed that there is some difference in the X vs Y dimension.
The longer plot length makes the problem more noticeable.
Is there a way to calibrate the plotter to get the tolerance equall?
Thanks,
dr
what makes you think it is x/y and not your tracking?  Longer cuts are where the tracking problem is?  if you can cut a 3" x 3"   6"x6" or perfect square then I don't see how it could be  x/y. You can also do test cuts with your machine.  You can download your user manual from the Graphtec website or  also  call  Graphtec  tech support    also you did not state what cutting software you are using.
draw a 6x6 square and then cut it measure it
and post the square that you made here and i can cut it and see if its your software or hardware
OK, maybe I am talking about tracking. I will do a 6x6 test and report back and check out the user manual.
Thanks for the tips.
dr
