benb
wot driver do i use for my refine eh721 for use with flexisign
EH721 Cutting Diagonal lines   :thumbsup:/u]
I have the EH721 using flexistarter. However, when I send item to be cut, the plotter cuts  diagonal lines for the length of the cutting job, without cutting any recognizable letters or images only lines.
I am using Vista toshiba laptop - Belkin USB cable - port set up is com4 -
The test for the cutter works
I can cut letters from Artcut but cant import vectors and if I drag and drop, the image is totaly distorted into long lines - which is why i purchased Flexi.
Anyone else had this problem?
Does anyone know why it could be doing it?
Or does anyone know how to fix it this problem ?
I have been working on this problem for over a week now.....
Any help would be apprciated.
Cheers Australia.
It sounds like static or usb problem. If you're on a laptop, I'd recommend a good external powered USB hub and make sure your cutter is well grounded.
Thank you  - I will look into it ....
I can now cut with artcut using PLT format only.
Hi,
Uscutter - MH721 is what I have selected. Though my plotter is EH721 which is not in the list of choices.
Not sure about the EH version, but if it were an MH, I would try the Roland PNC-1000 driver in Flexi.
help can someone help me with my EH721, i had it operating yesterday with artcut, on a 25pin parallel port, then when i was doing a cut the vinyl got all gathered up and i paniced an turned it off, then i released the vinyl and retuned the carriage away from the mess, i turned it back on and it does not respond at all. in my hardware devices it does not recognise any hardware attached, when i connect up my 9 pin to usb(Comp) it recognises it but i still can't get it to communicate with computer to cutter. this is damn frustrating, i was so excited with the operation. please anyone help me...
