robochan 0 Posted March 27, 2010 I need this to look good. Share this post Link to post Share on other sites
robochan 0 Posted March 27, 2010 This is as far as i can get. I cant select or change colors. Please help eagle2.zip eagle2.zip Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 27, 2010 you could hire forum member drakesis to do it. He is good and reasonable from other members personal experience. or use inkscape.org it is better at converting. http://www.excaliburcreations.com/ Share this post Link to post Share on other sites
Aanimalman 0 Posted March 28, 2010 ok, Third time's the charm, Here's a copy you can use. It will need some cleanup in SBE to put the layers where you want them but the layers are there and colored. I used photoshop to sepparate the colores and inkscape to vectorize each layer and recombine them and then pulled it into SBE to check it . All is there needs some fine tuning with the node edit feature and your all set. ok, finally got one up that seems to work Aanimalman OddBalls Novelty Yakima, WA eagle 1.eps eagle 1.eps Share this post Link to post Share on other sites
mark-s 1,126 Posted March 28, 2010 Post it in EPS or AI. mark-s Share this post Link to post Share on other sites
robochan 0 Posted March 28, 2010 Thank you so much. Share this post Link to post Share on other sites
