momoftwins
blade settings for cutting all the way through vinyl and backing
HI!  I have upgraded from a Cricut to a Craft Robo Pro and I am trying to learn the new stuff.  I need help with the blade settings.  I sell alot of my items as peel-n-stick so I need to know the settings to cut all the way through the vinyl and the backing.  Has anyone done this before and give me some clues?  I am using the RoboMaster program.  I bought the machine used and I'm not sure if the blade is old and dull or if I have some settings wrong.  Any help would be WONDERFUL!!
from what I understand to cut all the way thru you need a carrier sheet.  other than that I would think it would be like any other cutter and just expose a little more blade and pressure if needed
Dakota is right on the money with this one. You'll absolutely need a carrier sheet. After that it's just a matter of fine tuning blade depth and force to achieve the cut you're looking for.
