rodbuilder 0 Posted February 24, 2010 I have a CD with 85,000 fonts on it, but don't want to install them in the Windows "Fonts" folder because it takes forever to boot up the computer that way. So.........when you're using text with Flexi 8,5 Pro can ya' grab a font from a separate folder or a CD, from within Flexi - or are you limited to those that are already installed in Windows? Share this post Link to post Share on other sites
dinki 3 Posted March 5, 2010 This is a great question. I'd love to be able to use fonts without installing them to. Hopefully there's a way and someone will be able to tell us how to do it. Share this post Link to post Share on other sites
Dylan 0 Posted March 10, 2010 when flexi boots, it loads the installed windows fonts, so then the answer would be you would need to install the fonts and then restart flexi. I have a utility that I use that allows me to view both installed fonts and not installed fonts and select the one to install, it also has a test window, where you can type a text selection and see what it look like as you scroll thru the fonts. It is FreeWare, it is called AMP Font viewer http://www.ampsoft.net/utilities/FontViewer.php Share this post Link to post Share on other sites
