uscutterboy 0 Posted February 8, 2010 Hello everyone . Question of the day, How much do I charge per square inch of cut t shirt vinyl ? I am using Thermoflex and it cost me 50 dollars for 15 feet. Also do I charge for the wasted material ? Thank you all so much for your help !!! Share this post Link to post Share on other sites
bamafan2277 50 Posted February 8, 2010 I have a program that tells me what the cost per sq inch is and I calculate the lost amount too. I do try to squeeze in as much as I can and cut the items separate after weeding. You should look into Siser Easy weed from http://www.alpinesignsupply.com/ They have it for $32.00 per roll. Siser and Thermoflex are real close from what I've heard. I love siser becasue it is easy to weed and very thin and feels great on shirts. I am not at home right now so I don't know the prices I charge per square inch for the shirts. I will post later once I get home to my computer. Share this post Link to post Share on other sites
uscutterboy 0 Posted February 8, 2010 Killer ! Thank you, I look forward to it.. Share this post Link to post Share on other sites
bamafan2277 50 Posted February 9, 2010 Ok here is the breakdown of the vinyl your using currently Per sq inch is $0.0185 Per sq foot is $2.67 Per sq yard is $24.04 I would at least charge 3x what the vinyl cost as markup. For the siser from alpine the prices are Per sq inch is $0.0119 Per sq foot is $1.71 Per sq foot is $15.38 I get approx 3-4 rolls from alpine for $10 shipping. Share this post Link to post Share on other sites
uscutterboy 0 Posted February 9, 2010 Thank you for going out of your way for me. Is there a good software program to use for calculations ? Share this post Link to post Share on other sites
bamafan2277 50 Posted February 9, 2010 I use a program I got from a member here that he custom wrote the code for. You can go to his website at www.papsoft.com Its called Pap3. He wrote it for the sign business. It is great. you can keep inventory, invoicing, customer base, and many other things with it. I'm not sure if Pappy comes around much any more but you can email him if you have any questions with the software. Share this post Link to post Share on other sites
uscutterboy 0 Posted February 12, 2010 neat, thanks Share this post Link to post Share on other sites
uscutterboy 0 Posted February 12, 2010 When I try to cut the thermo flex, the material seems to not be held very well. It seems that as it moves, the vinyl moves off of track. I am using the mh-871 (something like that) any idea of how to keep the material from slipping off of track Share this post Link to post Share on other sites
bamafan2277 50 Posted February 12, 2010 are you cutting with the dull side up? I'm not familiar with thermoflex but if its like siser the dull side is the side you cut. the shiny side is the backing part Share this post Link to post Share on other sites
uscutterboy 0 Posted February 12, 2010 one side is clear plastic and the other is vinyl ? I am cutting the vinyl side. :- Thanks for the help I have my first 22 shirt order !!!!! Pretty excited. Hope this stuff works Share this post Link to post Share on other sites
Guest sciondrgn Posted February 12, 2010 General rules for tracking.. This is what i do. Line your vinyl up and roll out about a foot or so. Line it up as straight as you can then roll the vinyl back and forth a few times using the machine.. Check to see if the vinyl is drifting any.. adjust one side of the vinyl and try again.. If the vinyl is drifting to the right, slide in the right side, and same for the left, drifting to the left, adjust in the left side.. It takes a little practice to get it lining up perfect but after I while i can just about get it on the first try everytime Share this post Link to post Share on other sites
uscutterboy 0 Posted February 12, 2010 You are right, thank you. I would have never figured that out Share this post Link to post Share on other sites
