dill 0 Posted November 20, 2007 My pcut Has stopped cutting. When I press cut and the cutting screen appears, the frame arounud the graphic changes color ( I think from red to blue, or visa versa) and a small dotted line appears diagonally across it. When i press "cut tile" , the carrage of the cutter moves back and forth and stops Whats happening? Thanks in advance Don Share this post Link to post Share on other sites
tservice 3 Posted November 21, 2007 Recheck your settings. Share this post Link to post Share on other sites
tservice 3 Posted November 21, 2007 From the cut screen select setup, then comm settings. Check your baud rate, then on your cutter make sure your baud rate is the same. One last thing We have had the same problem from time to time ( if all settings are correct) We would select finish the go back to the cut screen then it normally will start working. I guess I should have asked, are you using Sign Blazer? Share this post Link to post Share on other sites
dill 0 Posted November 21, 2007 Yup. It's communicating with the pcut cause the head moves. It some kind of setting in signblazer thats keeping it from cutting. As I stated in my orional post, when I'm at the cut screen and push cut, the color of the boarder around the graphic changes and a thin doted line appears diagonally across it. Thanks Don Share this post Link to post Share on other sites
tservice 3 Posted November 21, 2007 In the cutter setup menu do you have direct selected or Use Cut Manager? Share this post Link to post Share on other sites
kenimes 42 Posted November 21, 2007 Is the carriage hitting either of the red buttons on the cutter? If so, it will lock up when it does. Share this post Link to post Share on other sites
dill 0 Posted November 21, 2007 No, I beleive that this is a software problem. Again, when I'm on the cuter screen and have the picture of the graphic shown going into the cutter, when I go to cut tile the color of the border of the graphic changes and a small diagoall dotted line appears across the graphic. The curer head moves back and forth once (which seems to tell me their is communication between cutter and computer). I was trying to print several of the same graphic across a 24" wide sheet at the time. Thanks Don Share this post Link to post Share on other sites
kenimes 42 Posted November 21, 2007 Right, the software is designed to show the path of the cutter head while cutting. If the path is being made, but the carriage only moves a little, then something must be wrong with the hardware on the cutter, or the communication between the computer and the cutter. Have you tried another connection cable yet? Share this post Link to post Share on other sites
dill 0 Posted November 21, 2007 That fixed it. I noticed what I was seeing is what shows as irs cutting. Thanks to all Share this post Link to post Share on other sites
