Cuttter 1 Posted January 31, 2010 I have been going round and round with signblazer trying to figure this out. I need to know how to do the reverse weld, also where do I find the reverse weld button to add it to the top tool bar and once I find the button how do I add it to the toolbar? I do not see the tool on the areas the manual says its at. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 at top> ARRANGE> WELD> REVERSE WELD. ALL THERE Signblazer 6.0 (this version is full version with all the cutter brands) Share this post Link to post Share on other sites
Jay2703 704 Posted January 31, 2010 I don't think reverse weld is there in the elements version. Try using Arrange + Combine instead. http://screencast.com/t/MzQ0YjU4N Jay Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 I don't think reverse weld is there in the elements version. Try using Arrange + Combine instead. http://screencast.com/t/MzQ0YjU4N Jay It's in the version ,I downloaded from the forum with full cutter brands.. SIGNBLAZER ELEMENTS 6.0 BASIC Share this post Link to post Share on other sites
Jay2703 704 Posted January 31, 2010 I don't think reverse weld is there in the elements version. Try using Arrange + Combine instead. http://screencast.com/t/MzQ0YjU4N Jay It's in the version ,I downloaded from the forum with full cutter brands.. SIGNBLAZER ELEMENTS 6.0 BASIC I don't have that version on this laptop, I just have the uscutter version and it's not here. Arrange + Combine looks like it does the same thing. Share this post Link to post Share on other sites
prestonservco 26 Posted January 31, 2010 my SBE doesn't have it either. Only 2 options under weld. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 http://forum.uscutter.com/index.php/topic,21665.0.html I don't have any of the nag screens either. just loads right up, Share this post Link to post Share on other sites
Cuttter 1 Posted January 31, 2010 Thank you everyone, I dod have SB elements, and there are 2 choices only. Where can I get the version that has everything. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 in the post up above,,,,or go to the signblazer thread, it is listed there. Share this post Link to post Share on other sites
Cuttter 1 Posted January 31, 2010 Thank you, I did check it out but the laserpoint is not in it's setup. So I can't use that version. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 Creation Pcut is there.. Laser point is a PCUT, with a laser Share this post Link to post Share on other sites
Cuttter 1 Posted January 31, 2010 But which PCUT there is 8 of them. Share this post Link to post Share on other sites
Cuttter 1 Posted January 31, 2010 speed, so in this version, do I also have to use it in the trial version always? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 signblazer will ALWAYS be a trial version, unless you purchase the PRO version. but if you search the Signblazer thread you will find the patch that takes away the nag screens that come up,, match your size of laser point with the same size of Pcut. you can check that out in the US CUTTER website. ,, or see if your machine has a model number on it. Share this post Link to post Share on other sites
Cuttter 1 Posted January 31, 2010 Thank you for the information, I have downloaded the software, to me this is an upgrade, with more features than the SB elements. I just cut with the pcut setting and is did a better job than it has been doing. Now I have to test it on a 6 ft banner. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 31, 2010 GREAT!!!!!!!!!!!!! NOW you can teach someone else.. Share this post Link to post Share on other sites
