Scotty 0 Posted January 30, 2010 Yesterday I got my mh871 I let it warm up for 24 hours the began to set it up. First I noticed that there is no ground cable? On to the next problem. I use flexi 8.1 I use the lpt port on the plotter and computer and use pnc-1000 driver in flexi. As of right now I can not get it to cut. It just says cutting 0%. Also has anyone else received there 871 with the measuring scale on the front and back not alined? Share this post Link to post Share on other sites
Scotty 0 Posted January 30, 2010 I got it to cut with the USB cable. Just with any font I cut the lines are very wavy. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted January 30, 2010 is there any way you can take a pic of one of the wavy cuts after you weed it? And put a dime or something in the pic to show scale? Share this post Link to post Share on other sites
Scotty 0 Posted February 1, 2010 Sorry for the crappy iPhone pic. http://i102.photobucket.com/albums/m117/scottyroddis/b6d87736.jpg[/img] Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 1, 2010 looks very familiar . . . another member had this problem and the problem went away when he took the cutter 60 miles away to another house. I think it was suspected EMI Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 Anyone have any ideas? The cutter can not be used because of this problem. I move the cutter to a different part of the house and it still has the same problems I am very dissapointed in us cutters Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 11, 2010 take a pic of your bladeholder where the blade sticks out and post please Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 11, 2010 just a thought back the blade length back to where it just barely is visible and increase pressure Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 The blade is barley out. I Tried increasing pressure. Decreasing pressure. Backing off blade and testing both. Different blades. I added two grounds. I've tried different cables. Different fonts. Different brands of vinyl. Different speeds. I don't know what else to try I tried taking the picture you can not see the blade in the picture. I'm starting to think the cutter is deffictive. It didn't even come with a test cut. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 11, 2010 if you are in southern Ohio you may have the EFI problem - the other member finally went to a copam after trying everything else to solve the issue. he took the cuttter to his moms 60 miles away and it worked great but in his home he never resolved it. that was a very rare thing though Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 11, 2010 The blade is barley out. I Tried increasing pressure. Decreasing pressure. Backing off blade and testing both. Different blades. I added two grounds. I've tried different cables. Different fonts. Different brands of vinyl. Different speeds. I don't know what else to try I tried taking the picture you can not see the blade in the picture. I'm starting to think the cutter is deffictive. It didn't even come with a test cut. what do you have the blade offset set at in Flexi? and what quality? Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 As of right now I am 10 miles from Detroit Michigan. I really hope that is not the case and I wasted $360. Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 Also my lpt port on the cutter does not work. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 11, 2010 it is rare for the efi thing to be a problem. have you contacted USC thru a support ticket to discuss it with them? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 11, 2010 As of right now I am 10 miles from Detroit Michigan. I really hope that is not the case and I wasted $360. what is your blade offset set at in Flexi? and your quality? Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 My blade offset in flexi is 0.03 what do you mean by quality? Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 My blade offset is 0.03 what do you mean by quality? I just placed a Help ticket with uscutter. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 11, 2010 Flexi offset is in inches, try 0.019 I have CURVE QUALITY IN MY DEFAULT JOB PROPERTIES I set mine at medium I use Flexistarter 8.5 and 8.6 Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 I tired offset 0.019 and quality medium and it looks worse but it's still just as wavy. Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 Also when I hit test on the cutter the lines are perfctly straight. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 11, 2010 have you tried using a different cutter driver? Isn't your driver/cutter listed at all in the cutter set up? here is the US cutter Flexi driver download. http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=44&nav=0,4 Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 I am using the the pnc 1000 driver Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 11, 2010 I understand you are using that one, did you try the driver download, I just posted.? Share this post Link to post Share on other sites
tlzimmerman 11 Posted February 11, 2010 Have you tried changing the speed your cutter cuts at? Try backing it down all the way to 4.....see if that makes a difference. The right combo of speed and curve ca make mine do that sometimes, but I can usually back off the speed and it will cut nice n smooth. Share this post Link to post Share on other sites
Scotty 0 Posted February 11, 2010 i just installed that driver you posted it is still wavy using that driver. thanks for all the help to everyone who has posted so far Share this post Link to post Share on other sites
