gossages 0 Posted January 12, 2010 Hi i use to use flexi sign but then the place i was working at i quit to go on my own, and im using Winpcsign - now not FlexiSign, i have a file i need converting from .FS back into .EPS so i can open it up in my other program can any one please help file attached the file attached is a .FS file but inorder to upload it i had to rename it so when you download it just re-name it back to a .FS file ;-) Thanks in advance. Share this post Link to post Share on other sites
the vinyl tree 0 Posted January 12, 2010 try this Copy of carls castles logo.eps Copy of carls castles logo.eps Share this post Link to post Share on other sites
MrMopar64 47 Posted January 28, 2010 You can export from flexi in EPS.... Just learned that today MM64 Share this post Link to post Share on other sites
rodbuilder 0 Posted February 24, 2010 I don't know if you can do this in pcsign. I bought that pile of garbage and sent iot right back to them, BUT see of you can "export" the file on the "File" part of the menue, then export it to a folder as an EPS file. If that doesn't work I'm no help! Save your nickles and dimes and get even a USED copy of Flexi. you'll take that pcsign and run it through your paper shredder!!!!!!!!!! I paid $1400 for my Flexi 8.5 off ebay and it's the real deal. Share this post Link to post Share on other sites
Sis834 0 Posted April 4 Hi, I recently received files for a customers car vinyl. The creator used Flexisign Pro and they are saved as .FS files. We use WinPCSign 2012 & 2018. We do not have the luxury to switch out to a new software. Is there a way to convert these .FS files over to something that I can open in WinPCSign? The photo shows what files that can be imported into WinPCSign! any direction would be appreciated!! thank you sissy@rpperformanceracing.com Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4 No, you would need the Flexi software to export as a different file format. Tell your customer to contact the creator or you contact the creator and send them in a format that you can use. Most would export as an .eps. Which can be used in most softwares. You would probably not even know which version of Flexisign pro that they used. An older version of Flexisign Pro cannot open newer files, or only up to a certain version. My Flexi software (10) is older and cannot open newer Flexi files. A newer version can open current and older files. It looks like they are up to version 22 now. Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 5 Down there in Sanford Florida, you can walk into a local Sign shop and ask for their help. Most retail signage places are implementing Flexi in their workflow. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 5 Down there in Sanford Florida, you can walk into a local Sign shop and ask for their help. Most retail signage places are implementing Flexi in their workflow. Quite the drive to Florida. Their Facebook current page has them located in West Virginia. A poster is even thanking Sissy. Dot come page is West Virginia. Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 5 Oh My, I seem to have referenced the O-P (gossages) who indicates Sanford Fl. USA!!! That was over 14 years ago. Rarely do I need a local sign shop to assist, but keeping good relations open is important in our field (as it should be). Just a few weeks ago, a certain job I was doing required a specific shade of Green. Didn't need much, just a smidgen. Ta-Da! The local FastSigns came through for me, they're run by a good guy. Share this post Link to post Share on other sites
