uarower 0 Posted October 22, 2006 I have flexisign pro and I need some help loading it could some one please help. Share this post Link to post Share on other sites
MarcelC 5 Posted October 23, 2006 If you have the Flexi program installed and want to set up the Refine plotter you can use the Roland PNC 1000 driver. Share this post Link to post Share on other sites
uarower 0 Posted October 23, 2006 I tried but it is still not working. I've tried with the lpt port and the usb port. I don't have a com port on my computer. Share this post Link to post Share on other sites
MarcelC 5 Posted October 24, 2006 Have you tried to cut with Artcut to see if that works ok? If it will still not cut with Artcut this probably is an issue with the communication between the PC and plotter. You can email me here directly so we can work this issue out faster. marcelc at selltopia dot com (replace at with @ and dot with .) Share this post Link to post Share on other sites
uarower 0 Posted October 24, 2006 Marcel, I just sent you an email with my status. Share this post Link to post Share on other sites
MarcelC 5 Posted October 24, 2006 Spoke with the customer and we worked through the issue. Turns out it the Com setting for the USB to serial emulator driver was set to Com 6 in the device manager. We set that to Com 1 and changed the device settings in Flexi to use Com 1 and it worked through USB. Share this post Link to post Share on other sites
greybuzz 0 Posted December 14, 2006 I am also having a problem with flexipro 7.5 the cutter works great using artcut but will not work on lpt1 or com1 with flexi. any suggestions? Share this post Link to post Share on other sites
thredz 1 Posted December 14, 2006 In flexi you have to use the roland pnc1000 driver.I think artcut uses the refine or selltopia driver,but it doesn't use it in flexi. Share this post Link to post Share on other sites
silviera 0 Posted January 18, 2007 i am also having problems getting it to print using flexi 6.5, and the LPT port on a Windows 2000 computer. Share this post Link to post Share on other sites
MarcelC 5 Posted January 18, 2007 Hello, if you are having problems getting the plotter to communicate with the computer please email me, or call us here during business hours. You can call us at 425-284-2282 between 9-3 Pacific Time M-F Share this post Link to post Share on other sites
Aardy54@54-Design 0 Posted January 20, 2007 Just got cutter (MH721) about a few days ago from Selltopia (finally won one on eBay lol) Using FexiSign Pro 7.6v2 Cutter setup says "e speed +4 vale" Baud 9600 Computer (Dell Inspiron9100XPS w/WinXP Pro) has no lpt or serial ports, only USB Flexi says it's on COM4 for this cutter / 9600 - 8 - n - 1 - flow control hardware - only box checked is CTS Loaded the virtual usb serial converter and that show up in device mgr under my usb ports Can cut once, if I'm lucky twice (switching rolls of vinyl) before it stops cutting and throws out a write port error (in prod mgr says "cannot open port). After that only way it will cut again is if I uninstall all the usb drivers from computer and let them reinstall. I know there's got to be a way to fix so I can cut and keeping cutting when switching vinyl or going to the next cut job ... so, where's the prob lay? Help please, before I go ballistic on this whole contraption LOL Share this post Link to post Share on other sites
