gmille39
MH871 TO WORK WITH SIGNCUT X2
I have my Copam CP-2500 working with signcut x2. It's off getting repaired so I bought an MH871 as a backup. How do I get everything(CorelDraw, Signcut X2 and the cutter) to work together like the Copam does. I don't wish to you the signblazere elements that came with the cutter. As soon as the Copam gets back, it's getting hooked back up and the Refine will take it's place as the backup.
Ok, I figured it out. I gave up on the usb connection until I get US Cutter support to hop on my computer and set up the drivers. The instructions also suggested you switch the usb mouse and get an adapter. Anyway, in signcut X2 you can go into settings and choose different cutters from a drop down list. It was that easy once I figured it out. I went to the LPT1 connection for the time being.
Great!  I was just about to jump in and tell you just set up your cutter in Sign Cut.  Exporting from Corel should work the same way.
Guest HowardI
We're glad you're up and running!
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
