segmkc
Can someone help me?
Awesome!  How do I connect that to the lettering for a cornhole decal? I put them together in layers.  Thanks so much for your time
The best way to connect that cat to your lettering is to cut the path that the cat is on using the scissor tool where you want to connect at, then cut the paths on the lettering where you want the cat to connect, then rejoin those line. Short cut for cutting tool is (ctrl + c), to rejoin grab open end points w/ white arrow tool and press (ctrl + j)
You can edit this graphic in SignBlazer, it won't easy, try to get a copy of illustrator to do your design work with, I use Signblazer at home, only to cut w/, design EVERYTHING in illustrator
I'm still having a ton of trouble with this. Anyone willing to vectorize it so I can cut it for a decal (eps) in SBE?
Wiling to pay someone to vectorize this one for me! I need to cut it for a  cornhole decal and I'm having a lot of trouble. Thanks for your time!
