muddywaterpirate
MH-721 cutting pressure?
I've been cutting vinyl with pretty much the default settings on my cutter, and have adjusted the blade many times.  One way it cuts through the vinyl, the other, cuts fine, but I have to weed the vinyl very carefully.
With all the settings, can added pressure be applied to cut the vinyl better?  The instructions that came with the cutter aren't very good at explaining things, but I don't blame USC, since it seems that way with most any product.
try decreasing blade sticking out and increase pressure. when all else fails try a cleancut blade!
I have a MH 721 and I set my pressure (top) 24 (bottom) 50 and the blade u can just barely feel it and it cuts fine like that.
But you can also do a search on the forum to get more info.
