Kysmiley 0 Posted December 7, 2009 I am having a hard time with off-tracking on my MH751. even if I try to cut something 2 feet long, some times not so much other times as much as 4, 5 inches. Could it have to do with the spring adjustments. I have lots of work finally coming up and need to get this figured out? Pat Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 7, 2009 After you have made sure the vinyl is loaded straight usually by pulling a couple of feet thru and readjusting the best you can by lifting the vinyl and repositioning it . . .if it is still not feeding straight then you can adjust the springs on the feed rollers to help the tracking. I have never had to do this after positioning the vinyl straight to begin with Share this post Link to post Share on other sites
YadirellT 0 Posted December 8, 2009 Make sure that that you vinyl is inserted straight. Usually I use the side of the cutter help align this up,and you might even want to use the ruler to help you align the vinyl in your cutter. But I think that Dakota's suggestion is going to get you better, more permanent results. Share this post Link to post Share on other sites
R A character Creations 0 Posted December 8, 2009 I am new and i put painters tape on my mh871 to help me line up the vinyl right now i use 24". Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 8, 2009 I am new and i put painters tape on my mh871 to help me line up the vinyl right now i use 24". great tip Share this post Link to post Share on other sites
Guest kenya Posted December 8, 2009 I am new and i put painters tape on my mh871 to help me line up the vinyl right now i use 24". great tip +1 Share this post Link to post Share on other sites
sdgirl 13 Posted December 8, 2009 I am new and i put painters tape on my mh871 to help me line up the vinyl right now i use 24". That is a great idea..do you have it going down the back side also? Christi Share this post Link to post Share on other sites
R A character Creations 0 Posted December 8, 2009 yes it is the same on the back and front the tape is cut way from the bottom roller and is clear of the white strip in front . It seems to help me in making sure that it is placed straight and so far no off tracking. But if it starts to I haave a visual to go by and I'm hoping it will save mesome headaches that may occure. Share this post Link to post Share on other sites
sdgirl 13 Posted December 8, 2009 That is awesome..I find myself leaning over the cutter trying to make sure it is all lined up right in the back and sometime I get it wrong..didn't think of putting tape on it.. Christi Share this post Link to post Share on other sites
Jeffrey06 2 Posted December 11, 2009 The tape is a great idea!!! I'm going to do this on mine. Share this post Link to post Share on other sites
rock jeep 1 Posted December 23, 2009 I am having the same problem with mine. In about 3' it will track over about 1.5"-2". I line the vinyl up with the measurements on the front and the back but it still tracks over. I have tried setting the rolls on the rollers and running one of the rollers through the roll of vinyl. But nothing seems to help. I havent tried what the other guy said. Do you just pull about 2' off the roll so it isnt trying to pull the roll too or pull it through the machine with the rollers tight? It will also cut long phrases or words in a slight arch and even more rare it will let one letter drop What could be causing that? The arch isnt that noticeable and I dont think it does it all the time but it bothers me when it does. Share this post Link to post Share on other sites
rock jeep 1 Posted December 23, 2009 I just tried pulling the vinyl out some and lining it up with the measurements on the machine and it still tracks over about 1.5" I think I will try to back off the springs on the right a lil cause it looks like that side is pinching the vinyl a lil more than the left. Do yall think that will have an effect? Share this post Link to post Share on other sites
YadirellT 0 Posted December 24, 2009 Usually the pinch rollers should be fairly equal in pressure. If they are not, they could cause the one side of the vinyl to go off track and cause it to pull one side at a different speed than the other. Can't really tell you whether this is the cause of your problem or not, but you will have a better idea when you look at your cutter, and get the feel for the pressure on your pinch roller. Share this post Link to post Share on other sites
