I have a MH-721 cutter that is cutting consistently incorrect & I'm not sure where the problem lies.  Here are the details any help would be GREATLY appreciated as I have a job to cut tonight.
I just cut a logo, general design is, text with broken oval approx. 19" across by almost 11" tall. The text was the word MERIDIAN with a broken oval around it. The top of all letters on the top right corner of the text are consistently incorrect with the chosen font. as if when it cuts across from left to the right & turns to go down, there is an issue.  I'm using Flex-Sign Pro.  The oval doesn't seem affected to the same degree the text is.  It's a block style font Arial Black.  Any help would be greatly appreciated.  Thanks
Try cutting from Signblazer, and see if you get the same result.  If so, please submit a ticket with the EPS file, and a picture of the image that came out.  That should help us diagnose the problem easier.
