lwsimon 1 Posted November 21, 2009 Just a quick note - I figured out that I was having some issues with the center roller on my cutter, but it wa s due to placement. When using cheap vinyl especially, if you put the roller right between the two bottom feed rollers, the vinyl will bunch up. Move the central roller an inch to either side, and the problem is gone. Share this post Link to post Share on other sites
cox signs 0 Posted November 21, 2009 yeah i ran into this same thing have to keep it off center Share this post Link to post Share on other sites
BannerJohn 1,324 Posted November 21, 2009 on my non-US cutters, there is a sticker telling you not to put a pinch rollere there. That part doesn't move. Share this post Link to post Share on other sites
lwsimon 1 Posted November 23, 2009 A sticker seems like a good idea that wouldn't add much cost. Surely you guys could find someone to cut some for you Share this post Link to post Share on other sites
Guest Posted November 24, 2009 Glad you were able to resolve your problem. I believe these stickers used to come with this machine. They certainly come with the rest of our value cutters. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted November 24, 2009 Glad you were able to resolve your problem. I believe these stickers used to come with this machine. They certainly come with the rest of our value cutters. yes,they did. My older MH721 had one, my new mh870 doesn't. Share this post Link to post Share on other sites
sarconastic 29 Posted November 24, 2009 my LP doesn't have it either. Kevin Share this post Link to post Share on other sites
BannerJohn 1,324 Posted November 24, 2009 It should be checked into..under the right circustances, damage can be done. The only time I did it (by accident,wasn't paying attention) It jerked the carriage off the track and broke the blade holder. Share this post Link to post Share on other sites
Guest Posted November 24, 2009 Why? Because the vinyl all of the sudden went at an angle and took the blade holder with it? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted November 24, 2009 the vinyl bunched up, the carriage caught on it,and I couldn't shut it off fast enough. I wasn't right next to it. Share this post Link to post Share on other sites
Guest Posted November 25, 2009 Ack, that's a bummer. I will work on getting the sticker added back to the machines, but I am sure it will be months before this change is reflected at the user level. Share this post Link to post Share on other sites
pitkin2020 1 Posted November 25, 2009 i only noticed this myself today and mine does have a sticker on the front of open rectangle no lettering so unless you knew what it was for you wouldn't have a clue. I had wondered why when i have the pinch roller in the middle exactly in the middle it bunches the vinyl up, had i have just looked underneath where it goes i would see that its making contact with a plastic block rather than a roller DUH!!! but atleast i learnt something new today Share this post Link to post Share on other sites
