John Thomson 0 Posted November 20, 2009 What blade offset do you guys that run a Refine with Flexisign use? John Share this post Link to post Share on other sites
Yones12 1 Posted November 21, 2009 I run a .23 offset Share this post Link to post Share on other sites
John Thomson 0 Posted November 21, 2009 Been messing with this setting today and for me 0.27 seem to be spot on with my MH 871......I have a 1351 as well so will try and get that perfect tomorrow. Would the blade manufacturer influence this setting? john Share this post Link to post Share on other sites
Cable Tech 0 Posted December 5, 2009 I'm running .13 offset on my 721 and Flexi and that seems to be the sweet spot on my machine. I am using a 60 blade. I think the offset is the same on a 45 and 60 if i remember right? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 7, 2009 offset should be different on 60 and 45 - can even change as the blade wears Share this post Link to post Share on other sites
MrMopar64 47 Posted February 5, 2010 I'm running .10 MH721 and Flexi I'm also using a 60 blade MM64 Share this post Link to post Share on other sites
sarconastic 29 Posted February 5, 2010 +1 Firemalt. that's while all blades come with a .25 offset "Starting" point. You then tweak one way or the other to make your machine cut better. Kevin Share this post Link to post Share on other sites
