han7681 0 Posted October 28, 2009 hi how can i correct into straght line? i want to make it straight line ( angle 0) thanks Untitled-1.ai Untitled-1.ai Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 28, 2009 open your grid, use pen tool. make 1 dot at one end . go to the other end.. or line segment... Dont you have a book with your adobe illy? Share this post Link to post Share on other sites
cuttingedge 1 Posted October 28, 2009 If you're just trying to make a straight line, why not just use the line tool, click, hold shift and drag to the right or left, click, and then let go of shift. This will create a straigt line, perfectly horizontal. Share this post Link to post Share on other sites
han7681 0 Posted October 28, 2009 thans for replying actually im correcting the file. the lines are not straight. i want to make all straight. thanks Untitled-3.ai Untitled-3.ai Share this post Link to post Share on other sites
cuttingedge 1 Posted October 28, 2009 Depending on what it is, sometimes it is easier to just recreate the file than to try to correct the lines that aren't straight. If it isn't too hard to do, it will ensure that you have straight lines, when they need to be. Untitled-3[1].ai Untitled-3[1].ai Share this post Link to post Share on other sites
Karl 0 Posted November 30, 2009 if its single lines, pick one line at a time and click the line , go to one end, click the "handle" it should highlight, click and hold that handle and press shift then move the end of the line around and put it close to where you want it. the shift forces a straight line. play with it for a while, it will become self evident. Share this post Link to post Share on other sites
